Old 08-11-2010, 11:32 AM
brains's Avatar
brains brains is offline
Exclamation Fix for no spark
Hopefully this will save some one many hours of frustration.
Fault :-
Intermittent spark, sometimes no spark at all (once died while idling on stand) sometimes ran good up to half revs and then bogged, hard to start and then back fired when it felt like it.
After doing reeds, rings, crank case seals, wiring loom, changing stator coil,CDI,HT coil all it needed was a 5 sec spray of contact cleaner in the loom and CDI connecting plug.....all faults gone
This is the first time my 05 300 has ever given trouble, if there is a next time I would like a easy fault!
Old 08-13-2010, 01:05 PM
darren's Avatar
darren darren is offline
Thanks for the heads up got that noted its bound to happen sooner or later.
1998 EC250
07 Shivers
2T racing PV Spacer
FMF Gnarly
Old 08-14-2010, 12:38 AM
noobi's Avatar
noobi noobi is offline
I had the same problem on my 07' 125, I went over everything many times, pulled the carb about 4 times, was just about to take it too the shop to get them to diagnose, but the fix was just that one of the female connectors was too loose, squashed it and the fit was much better, and never had a problem with that since.
Another no spark question... egesledder Enduro Electrical & Wiring 1 08-20-2010 06:27 AM
no spark... stainlesscycle Enduro Electrical & Wiring 9 02-17-2010 07:06 PM
EC 250 Spark plug Grampy Enduro Engine - 2 stroke 11 12-16-2008 12:24 AM
weak spark tallboy350 Enduro Electrical & Wiring 5 11-24-2008 08:18 PM
End cap with spark arrestor Qui-gon General Discussions & Announcements 3 05-08-2008 04:41 PM
