Old 09-12-2010, 01:20 PM
jhendr3702's Avatar
Default txt 200 pro question
was out tooling around on my 2002 txt200 pro and all of the sudden had a huge coolant leak.. the sensor came out of the housing and i dont see how it was in there..
can or should it be bypassed and wire the fan direct or get a replacement housing/switch ?
thanks in advance
jay
Old 09-12-2010, 04:22 PM
HuskyDude's Avatar
I would try and get it back in the housing again. Even if you had to use some Tie wraps or High Temp silicone to hold it in place. I've heard of wiring them to a switch. But I would rather have the fan only come on when needed not running on a switch.
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Old 09-12-2010, 04:52 PM
jhendr3702's Avatar
it is like something is missing..
here is the switch it is smooth..
here is the housing.. there is somekind of a groove on the inside of it..
it looks like an oring would go in it, but i dont know what would hold the switch in...
Old 09-12-2010, 05:31 PM
HuskyDude's Avatar
Tried to look it up for ya...but nothing prior to 05 is listed. Yes I would say a very small high tem o-ring is missing.
Give Jeff a shout tomorrow @ Gofasters 320-839-7143
He'll be able to help ya out.
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Old 09-12-2010, 06:15 PM
jhendr3702's Avatar
yep.... they always do..
i have some stuff on order there already..
thanks for checking.. the later txt's they moved that switch...wonder why
Old 09-12-2010, 06:24 PM
HuskyDude's Avatar
Ya I went out and pulled my tank on my 07. And I'm pretty sure it's located in the rad somewhere.
I think I remember a little metal clip holding the sensor in place on my old JTR 270. (inline tee same as yours.)
Let us know how you make out.
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Old 09-13-2010, 05:40 AM
jhendr3702's Avatar
will do...thanks
Old 09-13-2010, 02:48 PM
jhendr3702's Avatar
as a follow up... if you are ever looking for gg trials info..
lost of parts manuals..
http://www.trialspartsusa.com/tech.html
Old 09-14-2010, 07:06 AM
jhendr3702's Avatar
it appears the fan has quit also... that is probably what started this deal..
got hot and pushed the sensor out....
Old 09-14-2010, 04:47 PM
HuskyDude's Avatar
I would think your rad cap would have popped first.
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
