Old 04-07-2007, 05:06 AM
speed addic speed addic is offline
Question which air filter?
the parts crossover list shows all the air filters that i can use. But which one fits an 06 ec 200?
Old 04-07-2007, 05:54 AM
eff's Avatar
eff eff is offline
I think the are all similar. I have used the 2000 CR250 filter in my bike.
Twin Air also makes a GasGas specific filter, but the CR250 filter fits fine.
Old 04-07-2007, 12:32 PM
JoshP's Avatar
JoshP JoshP is offline
Moose also makes a GasGas air filter, part # M761-20-43
states it is for GasGas 125/200/250/300 97-07. This is the filter I have been using and it fits fine.
Old 04-07-2007, 04:04 PM
All years same except '07. I have a spare '07 Twin Air already, it seems a bit smaller in dia. but longer.
Old 04-15-2007, 02:27 AM
motorhead's Avatar
motorhead motorhead is offline
Question exactly which year twin air
Does the rubber grommet in the twin air fit the cage snugly?I purchased a uni filter last season for a honda cr and the grommet is larger than my cage where the bolt goes through (on the inside) Cant remember what year uni I purchased but I'm thinkink of ordering a stock gas gas filter so I KNOW it will fit proper.05' DE 300
Old 04-15-2007, 08:33 AM
The Twin Air is fine. I have several of them and they all fit good.
Old 04-15-2007, 08:42 AM
dirk's Avatar
dirk dirk is offline
when i started running the moose filter i had to drop the main in the carb
Old 04-15-2007, 05:51 PM
SpeedyManiac's Avatar
The Twin Air GasGas specific filter fits perfectly.
Old 04-15-2007, 10:10 PM
REVERUP's Avatar
REVERUP REVERUP is offline
On both my 04 an 06 300's I have always used the No Toil Gas Gas spicific filters and the fit is very good, along with durability. I do use No Toil filter oil and its cleaner so I'm not sure how they hold up to solvents and different brands of filter oil.
Old 04-16-2007, 07:21 AM
I have one of those as well. Good quality filter, but the fit seems a little bigger on the cage. When I install it I leave it a little loose at first and take extra care to be sure the foam ring is under the cage all the way around. I use No-Toil as well and both their filters and Twin Air have been fine for many cleanings/oilings.
need a new air filter any suggestions.... dareuk Enduro Product Reviews 4 03-24-2010 03:05 PM
pre-filter 2stroker Enduro Intake/Carburetion - 2 stroke 6 04-26-2009 08:56 PM
Air filter anathema Enduro Engine 4 stroke (including EFI & Exhaust) 16 10-29-2008 07:54 PM
Which air filter for 07 EC Tom Zelko General Discussions & Announcements 9 06-29-2007 10:09 AM
FSE Oil Filter McGuiver Enduro Engine 4 stroke (including EFI & Exhaust) 5 05-15-2007 08:49 AM
