Old 01-03-2011, 11:03 AM
compmoto's Avatar
compmoto compmoto is offline
Default '11 E-start bike batteries
Shorai brand batteries are much lighter, and have ALOT more CA,and a long shelf life also ... yes,we are a dealer for them ... they are lithium iron type batteries...I sent Clay a message about these as well...they aren't more expensive than Yuasa,or others.
XC300,RM250,X440,EC125
https://www.facebook.com/groups/gasgasoffroadriders/
Old 01-03-2011, 11:57 AM
Krieg's Avatar
Krieg Krieg is offline
Which one will fit the XC 300? How much weight savings? Cost?
Old 01-03-2011, 04:08 PM
webmaster's Avatar
Administrator
It looks like it uses the same technology as turn-tech batteries. I put a turn-tech in my husky to save weight.
http://www.turntechbattery.com
One nice feature is that in cold weather the lithium iron phosphate batteries will self heat - so they gain in cranking amps as you hit the button multiple times.
I seriously doubt that these cost less than the yuasa at oem pricing - it looks like these are approximately $100 for the lithium-iron.
As far as weight loss - it is significant - the website says weighs 1/5 of original lead/acid battery (might be a stretch) - a quick way to drop a couple of pounds up high on the bike.
Old 01-03-2011, 04:42 PM
Krieg's Avatar
I checked them out at the Shorai website. Looks like a much slicker package with many more size/capacity choices than Turntech. Much cheaper than Turntech too for a larger capacity. I may have to try one of the 9 A/H for $109.00.
'11 Husky CR150, '11 GasGas XC 300-E, '11 Kawasaki KX250F, '71 Hodaka ACE 100B+
Old 01-03-2011, 08:19 PM
HydroDog's Avatar
HydroDog HydroDog is offline
I seen the Shorai batteries at the Seattle Cycle Show. I was talking with the sale rep. about them and picked up one that was compairable to a YTZ7s that I thought was just a empty demo. When he told me that that was the real battery I could not believe it. It felt like a nothing. A friend of mine purchased one and found out that the only draw back is if you have a drain on your electrical system and deplete the charge, that it you can not recharge it.
07 GG EC 300
05 KTM 250 exc
99 KTM 640 enduro
Old 01-04-2011, 10:15 AM
rosco's Avatar
rosco rosco is offline
Why can't it be recharged? Do you mean that the bike won't charge it or it can't be recharged period. I've had NMH batteries get completely drained that would not take a charge. All you have to do is hook another battery up to the charger that has a charge along with the discharged batt. Its almost like the discharged batt. has to be jump started with a good batt. to get it charging again.
Rosco's Motorcycle and ATV
Rapid City, South Dakota
www.roscosmotorcycle.com
Old 01-04-2011, 08:30 PM
HydroDog's Avatar
My friend has tried to charge it with an optimate charger but the most it will charge up to is 7 volts.
07 GG EC 300
05 KTM 250 exc
99 KTM 640 enduro
Old 01-04-2011, 10:50 PM
Brian's Avatar
Brian Brian is offline
Yea unfortunately that is how the lithium-xyz flavor batteries are. If a battery cell gets depleted below some nominal voltage it is effectively dead.
I know with batteries for that Radio Control hobbyists use the chargers and batteries have circuitry to charge the cells evenly and I believe protect the cells from discharging below the that nominal voltage.
2006 Gas Gas EC250
2011 Husaberg FE390
Old 01-05-2011, 05:19 AM
iancp5's Avatar
iancp5 iancp5 is offline
So do you need a special charger? I looked on the Shorai site and they didn't have a charger yet!!! Does the new Optimate 6 charge them?
Maybe you need a Laptop charger!
Old 01-05-2011, 10:36 AM
rosco's Avatar
I spoke with a quy from trail tech about their lithiom ion batteries. I was curious if a guy could use the batteries for running the helmet lights on the bike. He said that the charging system on the bike would not work with the lithiom ion batteries. I have been running the NMH batteries and they work just fine.
E-Start Kit aflica General Discussions & Announcements 6 04-26-2013 05:57 PM
Getting trials bike clutch feel on an enduro bike? SpeedyManiac Enduro Chassis & Body 3 12-01-2010 02:11 PM
Lugging the bike and stalling - jetting, technique, wrong bike? stay_upright Riding Techniques & Training 21 04-18-2009 05:23 AM
Free cordless drill and circ. saw - batteries bad. jyellard General Discussions & Announcements 3 12-25-2008 08:37 PM
