Old 01-22-2011, 12:52 AM
tprnottp tprnottp is offline
Default Ethanol and Two-strokes...
Question: Since the EPA has deemed it necessary to increase the Ethanol content of pump gasoline to 15%, what are you running in your two-stroke to compensate for the addition of ethanol???
In short, are you using a fuel additive along with your favorite premix lubricant, or have you switched to "pure" unleaded race gas???
Inquiring minds would like to know.
Thanks for the input,
TP
EC 300
Old 01-22-2011, 06:38 AM
mcnut's Avatar
mcnut mcnut is offline
I have two gas stations close by that sell 110 octane leaded gas at $5.79/gallon. I mix 2 gallons of it with 3 gallons of 93 octane unleaded.
Old 01-22-2011, 09:13 AM
Bobt250's Avatar
Bobt250 Bobt250 is offline
I didn't think you could buy leaded gas at the pumps anywhere. I wish I could find that here.
2011 EC300
Old 01-22-2011, 09:20 AM
Ethanol is not good.
On my 2001 Gas Gas, my rings and power valves were gummed up from it. I let the bike sit for a few months and it would not even kick over.
Star Brite make an additive the really works. It will even clean out carb jets.
http://www.starbrite.com/sproductdetail.cfm?ID=1159
Old 01-22-2011, 09:22 AM
In Oklahoma there are sill a few gas stations, usually one in every town, that sells fuel with no alcohol. I buy 91 octane and it works fine in both my 2 strokes.
Old 01-22-2011, 09:55 AM
I used to mix VP Red race gas 50/50 with pump premium, but it got too expensive and a hassle if I needed gas fast. The Starbrite Startron additive has worked great so far with pump premium. Biggest problem is the inconsistency and effects on jetting. Be careful in cold weather.
Old 01-22-2011, 01:46 PM
iajim iajim is offline
Startron additive is good, a 50/50 mix of 15% methanol pump gas with non- oxygenated (premium) gas is OK. Your octane rating should be high enough to prevent detonation. Actual methanol content is down to 7-8 %. You can also run a "castor based" oil. Maxima 927, Klotz Benol, there are many others as well. Castor based oils mix well with alcohol.
Old 01-22-2011, 02:02 PM
Clay's Avatar
Clay Clay is offline
Banned
Here is a site where you can find non-ethanol gas stations.
http://pure-gas.org/index.jsp?stateprov=ID
Old 01-22-2011, 03:50 PM
Most synthetics do as well, but the ethanol absorbs moisture from the air and causes some components to separate. Its worse with ester based synthetics like Redline. Castor based oils are very dirty.
Old 01-22-2011, 04:25 PM
Wyoming Kim's Avatar
Wyoming Kim Wyoming Kim is offline
Thanx for the link Clay.....I verified the info that was stated for one particular station near my location and now I know where I'll be purchasing ethanol-free fuel.
EPA considering raising ethanol to 15% eff General Discussions & Announcements 17 06-01-2011 11:27 PM
New Berg 2 strokes Silver General Discussions & Announcements 9 07-07-2010 07:12 AM
The future of two strokes kim General Discussions & Announcements 3 02-17-2010 10:08 PM
Drowning Two strokes FFRDave Enduro Engine - 2 stroke 1 05-11-2009 09:43 PM
Any 07 2 strokes in the US yet? ScottyR General Discussions & Announcements 33 01-20-2007 07:48 AM
