Old 01-30-2011, 12:33 AM
REVERUP's Avatar
REVERUP REVERUP is offline
Default 2011 300E interesting pics
A couple pics I took of things you might be interested in seeing if you haven't updated your Gas Gas for a while. The evolution continues and yes the factory is listening. I took these today while working to further set up my 2011 300E.
Roscoe
New and improved coil mounting much more rigid and protected, not sure heard grumblings it may interfere with adding aftermarket larger tank.
Air filter changes a little less roomy with the E start but still very doable.
They really have went to great lengths to try and lighten things up recently. This new frame design has signs of it all over. Here is one instance I found that is pretty substantial. It may also contribute to chassis feel. They really shrunk the euro steering lock mechanism down also.
Threaded brass inserts in gas tank
Old 01-30-2011, 10:19 AM
PEB PEB is offline
Looks like the brake line will still rub the cases, mine had a deep gouge in the cases from that. In fact I found numerous spots all over the bike where destructivce rubbing was taking place. Does the battery swing out of the way?
Old 01-30-2011, 11:41 AM
john01 john01 is offline
Very clear pics thanks for posting them and pointing out the changes.
Old 01-30-2011, 11:46 AM
widebear's Avatar
widebear widebear is offline
Banned
You cant see it in the picture but the forward brake hose loom has a relief in it to accept a zap strap so you can preload the hose away from the cases.
Old 01-30-2011, 12:00 PM
PEB PEB is offline
Is "zap strap" canadian for zip tie?
Old 01-30-2011, 12:08 PM
widebear's Avatar
Banned
oh yeah- eh
Old 01-30-2011, 12:30 PM
pj7's Avatar
pj7 pj7 is offline
Frame looks much better, that cast piece looks very KTMish. I'm Still not a electric start two stroke fan, and the battery looks big and heavy, maybe overkill. The orange bikes are using a smaller one, YTX4. Glad to see the tank inserts too. Great pictures!
Old 01-30-2011, 03:12 PM
Krieg's Avatar
Krieg Krieg is offline
Probably why the GG starter still works after 5 starts .
'11 Husky CR150, '11 GasGas XC 300-E, '11 Kawasaki KX250F, '71 Hodaka ACE 100B+
Old 01-30-2011, 10:31 PM
REVERUP's Avatar
Just so you know the brake master cylinder is not tightened down and the shock has been removed so its not really sitting how it would be normally. I will check into if it rubs. My 08 didn't but I like to run my chain long to gain some straight line stability by making the wheel base a little longer.
Yes the battery is just sitting there on a rubber mat that is also removable from the tray. The seat recess is what keeps the battery in the tray. I could not feel the recess through the seat foam now. Not sure but that could change as the foam breaks down some. I really don't hit the seat to much though so probably not a bother for me anyhow.
Roscoe
Old 01-30-2011, 10:44 PM
REVERUP's Avatar
pj7 Yep the battery is a hog and I will be replacing it with a Shorai. You can drop 4.1LBS just by doing this swap. Cost is from 100$. and improves cranking amps etc.
I read Gas Gas claims the e start adds 7.7LBS so if you can get the system down to under 5LBS by swapping out the battery it isn't such a penalty and is nice to have in some situations.
Roscoe
interesting read, highland motorcycles and GG jostby General Discussions & Announcements 20 07-12-2010 11:49 AM
Interesting WEC speculation Berkyboy General Discussions & Announcements 3 09-28-2009 06:11 PM
Interesting Log Crossing! Boomhauer Pictures & Videos 3 02-11-2009 02:13 PM
Your before and after pics! 2 strokes 4 life Pictures & Videos 0 01-18-2009 12:28 PM
Interesting thread over at e-dirt.co.za TooFastTim General Discussions & Announcements 1 05-02-2008 04:27 AM
