#11
My 2010 EC300 has the older style black screw on cap on top.
#12
Roscoe
Huge thanks: GAS GAS OFFROAD US, Skagit Powersports, Cycle Gear, LTRacing, Scorpion Racing, users of GasGasrider.org, and CFMC! |
#13
I adjusted my 2010 300 so that the seam in the floats, is parallel with the bottom of the carb, while holding it upside down. I remember this being a generic recommendation from years ago. I have no idea what the height is in mm, but I know it's quite a bit lower than factory. I seem to get better fuel range now.
#14
The goal is to tilt the carb just enough for the float weight to just have the metal tang "lightly" resting on the spring (and not depressing it). When you are in this state of zen, you look at the seam molded into the floats and it should be typically horizontal with the float bowl mounting surface. Some folks measure the height but it really doesn't matter, every bike is different and some like more/less fuel in the float bowl. Getting the float seam approximately level is a good starting point. If you need to adjust the float height, you bend the small metal tang touching the spring. It only takes a very small bend. Repeat the tilt test until you are happy.
Matt Current: 2009 Yamaha FZ1 Previous: 2001 GasGas TXT280, 2001 GasGas XC250, 2004 KTM 200EXC, 2007 GasGas EC250, 2007 Husqvarna SM610, 2008 Husqvarna WB165 |
How to set float level. Revisited. | gasgasman | Enduro Intake/Carburetion - 2 stroke | 48 | 11-10-2018 05:11 AM |
Could somebody explain what all is required to street legal a two stroke? | dank | General Discussions & Announcements | 7 | 11-24-2010 07:54 AM |
Zokes oil level? | jostby | Enduro Suspension | 2 | 06-20-2009 11:29 AM |
Fork oil level ? | Brian VT | Enduro Suspension | 4 | 03-10-2009 08:57 PM |
WP Fork Oil Level | MattR | Enduro Suspension | 11 | 08-02-2006 10:40 AM |
