Old 02-04-2011, 11:11 AM
Gerko Gerko is offline
Default TDC marks ???? Fse 400
Any body know where the tdc marks are for the fse 400 2002/3 model.
As the timing chain snagged and snapped , nothing was marked. Manual doesnt seem to show. I am trying to time the beast
Old 02-04-2011, 02:53 PM
iancp5's Avatar
iancp5 iancp5 is offline
I stuck a knitting needle down the plug hole and watched it.
Be very careful with GasGas manuals and the torque settings, some are wrong.
Old 02-04-2011, 03:43 PM
Cheers , thats the only way i could think of working it out. Surely there should be a mark. Well thats my thoughts and not GasGas's
Old 02-07-2011, 11:27 AM
Qui-gon's Avatar
Qui-gon Qui-gon is offline
Assuming the cam chain area was not the issue for the teardown you should always verify the marks at tdc firing stroke. If it is not obvious you can then mark it up yourself using an engraver or centre punch. That way you can always put it back as it was
06 Gas Gas FSE 450 USA
07 Gas Gas FSR 450 UK with motard and dirt wheels
Old 02-07-2011, 07:25 PM
The cam chain was the reason for teardown. Looking at the stator side its marked evenly, so am i right in thinking it sparks twice??. If not how do i work out which is the firing stroke, Im sure ive read it fires twice.
Old 02-08-2011, 01:19 AM
iancp5's Avatar
That confused me too and I came to the same conclusion, it must fire twice.
Old 02-08-2011, 11:14 AM
Qui-gon's Avatar
As that is the only trigger and occurs every revolution I believe its the ecu which works out which spark to miss or not. I also think that the ecu works out when to open the injector once as with the spark otherwise there would be 2 injector pulses (not good) as well as 2 sparks which is not unusual
Old 02-11-2011, 03:08 AM
iancp5's Avatar
There is nothing as far as I can tell for the ECU to determine which is the firing stroke so how can it work it out? There's no camshaft sensor, it seems a very simple system.
It is possible both injector and spark are "wasted". I don't think the bikes attempt to comply with emission regs like a road bike and the injector is farther back than many road bikes so maybe the buffer effect of the inlet tract smoothes it out so it works good enough. Of course if they did it properly we could probably get much better mileage!
Old 02-12-2011, 02:17 PM
Qui-gon's Avatar
Both scenarios are possible I guess. It would be possible to set the injector pulse and spark whilst cranking....could explain why these bikes never burst into life on the first compession stroke whilst cranking? As there is little or no information about these ECUs around, except on one of the Fiat forums, it will be difficult to find out. But I am going to find out. Just waiting for a piece of kit to arrive!
Old 02-12-2011, 03:36 PM
well i have a 50 / 50 chance of getting it right if they dont fire twice, i will update accordingly. If it fires though i wont be taking it apart to see if i just guessed right
Timing marks on 03 400 fse endoed Enduro Engine 4 stroke (including EFI & Exhaust) 0 10-13-2010 11:16 AM
