Old 10-19-2011, 08:36 AM
Eric K Eric K is offline
Default SG10 boots - how to fix a pressure point?
I bought a used pair of SG10 boots in good condition.
The boots have a pressure point on the inside of leg about 4 inches above my ankle. The pressure point is caused by an inward buckle of the leather where the boot flexes.
Any ideas on how to fix this?
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 10-19-2011, 10:48 AM
They may soften up some once broken in. Soak them in some water and go ride?? Both legs or just one side?
Old 10-19-2011, 07:13 PM
Both sides have the same pressure point.
Since they are used & fully broken in, it looks tough to reform the way the leather has buckled in toward my leg.
However, I will try wetting and clamping to force the buckle the opposite way.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 10-19-2011, 07:53 PM
Shaving cream works also. Fill the boot up and let it sit for a few hours.
You can also stick an inner tube in the boot and inflate it to "spread" the pressure point outwards.
Old 11-03-2011, 04:58 PM
seitz64 seitz64 is offline
Default sg10 boot
1965 first nite marine corp boot camp 3 hrs beating the crap out of each doot with the other it worked! good luck
Old 11-03-2011, 05:14 PM
Default sg10 boot
no we didnt wear doots yes boots !
Old 11-09-2011, 02:09 PM
motorhead's Avatar
motorhead motorhead is offline
Hit a hidden treestump with my Gaerne fastbacks at our last enduro last fall. The impact broke the buckle and the plate it fastened too. Ordered new buckle and made a new plate with more surface area. I wonder if you could do same,maybe a larger surface area would fix the pinch point?
TeamFlannelOutdoors-somewhere South of I80
05' Gas Gas 300 DE
(Son's) 22' Rieju MR300 80th Anniversary Edition. 02' Gas Gas 250 XC
Moto Farm motor and suspension service 309 310 2540 leave a message
www.halls-cycles.com
Tank cracked at mounting point Bailey28 Enduro Chassis & Body 8 05-15-2013 01:47 AM
tyre pressure Rabbitist Enduro Chassis & Body 7 05-21-2011 09:09 AM
Clutch Friction Point mcnut Enduro Engine - 2 stroke 13 05-09-2011 08:56 PM
400 FSE Fuel Pressure Gi_GASGAS Enduro Engine 4 stroke (including EFI & Exhaust) 6 04-24-2010 02:06 AM
What is the point of the bolt on the side of the head? Motarded1 Enduro Engine 4 stroke (including EFI & Exhaust) 1 02-03-2009 06:17 PM
