Old 10-23-2011, 03:19 PM
Roscoe.
I turn on headlight every time I ride. Our trails are two-way, so any advance notice is benificial to my health.
I think I may have a defective headlamp reflector. Only the lower half has the black oxidation on it. There is NO indication of any overheating concerns with the headlamp shell where the bulb sits.
I did have some water condesation in the head lamp before this happened. Maybe related?
Old 10-23-2011, 08:04 PM
I've got condensation on the inside of mine .... pretty much since day one. I figured it was from splashing through puddles and washing the bike. I'll have to take a closer look at the reflector. If I was more electronically inclined .. I'd be looking into how to refit the stock unit with some 35w led units
Old 10-24-2011, 09:20 PM
matt_tidball matt_tidball is offline
I got a 55w H4 replacement. It puts off alot more light. I have not had any issues running this bulb.
Old 10-25-2011, 06:23 PM
REVERUP's Avatar
REVERUP REVERUP is offline
Thanks guys I bought a standard Sylvania 55 wt H4 bulb for 10$ I could have got one with more lumen's of light out put for twice as much but the reliability of the bulb decreased majority.
Cheap upgrade I figure. Haven't plugged it in to try it yet cause my MX number plate set up is on the bike until O' dark 30 this Saturday. Then I'll add my lighting for my night laps. BRAAAAP!
Roscoe
Old 01-24-2012, 09:52 AM
Be careful, the socket/reflector may not be able to handle the heat of both hi/low at once. I have not seen a newer light assy, but I have melted an older one doing this.
Old 01-27-2012, 02:44 PM
savage sausage's Avatar
savage sausage savage sausage is offline
Originally Posted by gasgasman View Post
Mine blew after the 4th ride.
I plan on putting a HID bulb in there next. The OEM bulb is a 35w H4 bulb.
I was thinking of going down this route, but I have one question as my bike doesn't have a battery ...is it still feasible to fit one without a battery?
They are ten a penny now on ebay of course you get what you pay for but can it work without a battery.
Any input would be greatly appreciated.
http://www.ebay.co.uk/itm/MotorBike-...item23192206f7
Old 01-27-2012, 06:34 PM
I don't know if you need a battery.
Cycle Gear had a blow out on HID bulb kits. But, they were too long to fit behind the headlight bezel.
Old 01-28-2012, 05:53 AM
K thanks i'll make some enquiries into it.
Old 01-30-2012, 03:01 PM
If I needed a bright headlight, better than stock, I'd work out an LED option. Very bright, low power consumption, extremely durable. All you need is a rectifier and capacitor. If the DC is less than 30V you don't even need a regulator for the lights I'm familar with. You can even run at least one and likely two off of a 35W 2K-2. Not cheap though.
Old 02-03-2012, 12:45 AM
GasTimppa GasTimppa is offline
HID needs DC power and your bike is AC (no battery). AC kills HID ballast in few seconds. For more information there is few topics how to get DC power from your bike. I had HID in my -07 and light was unbelievable. With -11 it is supposed to be even better.
There is no such thing as bad weather! Only riding gear is improper or insufficient
When it hurts you know you're allive!
Gas Gas EC 300 Factory Racing 2012
- Ohlins TTX both front and rear
- Rekluse Core EXP 2.0 + Rekluse clutch basket
- Scalvini full exhaust system
- S3 Head
- Trusty adjustable PV cover
That was ultimate setup for me...
Now trying something else for a while...
2001 XC 300 headlamp bulb jhendr3702 Enduro Electrical & Wiring 11 07-21-2011 03:27 PM
Headlight Bulb Kurdt Enduro Electrical & Wiring 1 09-01-2010 10:23 PM
FSE450 bulb vwboomer Enduro Electrical & Wiring 1 04-01-2010 09:01 PM
Bulb rating for 2001 ec300 johns2394 Enduro Electrical & Wiring 0 12-02-2008 01:12 PM
