Old 02-03-2012, 12:56 PM
jens jens is offline
Default gasgas ec300 engine problem
hey,
I bought a gasgas ec300 from 2002. I been riding it 3-4 times but now i got some problems with my engine.
But now the engine got trouble to stay on when im not giving gas.
ive been searching for a while and i found out that when i remove the cover off the power valve the engine runs perfectly.
anybody got an idea what the problem could be?
(sorry for my bad english i speak dutch)
Jens
Old 02-03-2012, 02:07 PM
GasGasDreamer's Avatar
GasGasDreamer GasGasDreamer is offline
Your pilot jet is dirty or clogged.
Another very weird thing happened to me once.
I adjusted the air / fuel screw while the bike was running.
All was well for an hour or so and then it started acting like there was some weird erratic electrical problem.
I replaced the plug and it disappeared.
But i am assuming that you changed the plug, cleaned the airfilter, didnt leave a towel in the intake boot, have good clean gas, and had sure your stator is dry..
2002 Husberg FE650e
2006 GasGas EC300
2014 Sherco SER300
2014 Beta Evo Factory 300
Old 02-03-2012, 02:44 PM
stainlesscycle's Avatar
check for restriction in pipe/silencer
07 ec300
www.stainlesscycle.com
Old 02-03-2012, 04:35 PM
yes i did check all of that. the problem also started while we where doing a trip. i changed the plug about 3 times.
Old 02-03-2012, 04:36 PM
i will check this tomorrow. it might be possibel and it would also explain the problems.
Old 02-03-2012, 04:57 PM
do you mean you ride it with the cover off?
2002 Husberg FE650e
2006 GasGas EC300
2014 Sherco SER300
Old 02-03-2012, 05:00 PM
i dont know if this can happen on mc but on cars the exhaust can look great but in reality the second inner wall collapses and the car will run for a little bit then die.
on a car you can use a vacumm guage to check for this. at first reading is normal then it starts to drop and continues to drop until it dies.
i dont thing the expansion pipe is a double wall.
the silencer should be easy to take apart and see.
best of luck.
please report back..
2002 Husberg FE650e
2006 GasGas EC300
2014 Sherco SER300
Old 02-03-2012, 05:08 PM
no i dont ride whitout it. i just whas searching the problem when i got home, and i thought there whas a problem whit the powervalve so i removed it and started the engine. then he whas running fine but when you close it he dies again.
Old 02-03-2012, 05:09 PM
best of luck.
yes, you explain kinda what happends. il remove the silencer tommorrow and check it out. tomorrow i wil report if this whas the problem or not.
Old 02-03-2012, 05:17 PM
HuskyDude's Avatar
Isn't there a little vent tube coming from the Power Valve box? That could be plugged.
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
03 EC300 crank bearing problem bwalker98 Enduro Engine - 2 stroke 4 05-04-2010 05:05 PM
2006 EC300 problem fury1 Enduro Engine - 2 stroke 29 06-09-2009 05:40 PM
ec300 clutch problem dirtjunky_uk Enduro Engine - 2 stroke 13 02-27-2009 08:08 AM
Strange Problem With My Gasgas Ec300 Am Ready To Burn It, GasGas.ec300.Andy Enduro Electrical & Wiring 14 01-17-2009 07:59 PM
Gear box problem 07 ec300 peterr Enduro Engine - 2 stroke 5 02-26-2007 01:07 AM
