Old 02-14-2012, 10:33 AM
300ec's Avatar
300ec 300ec is offline
Default sound of the engine
Hi all!
please, listen to the sound of the engine
this is a normal sound? I think the wrong sound at low revs
0:38 sec and 1:45
http://www.youtube.com/watch?v=vE-j6pc74cw
2009 ec300 Nambotin rep
2006 txt280pro
Old 02-14-2012, 03:22 PM
Originally Posted by 300ec View Post
Hi all!
0:38 sec and 1:45
When you say low revs you mean as you come onto the throttle?? It just sounds really rich to me.
Has it only just started doing it? How many hours on the bike? Ever had a top end/rings? Does it feel super soft/weak power off the bottom? Like you have just lost a lot of grunt?
If it was running strong and just started doing this I'd start with the simple things. Pipe off, check the power valve is in the closed position (attachment 1) Use the kick starter to roll the piston over and check the rings for blow by (attachment 2). If the powervalve isn't in the right position report back and we'll go from there. Snap some pics if you can. They always help
Old 02-14-2012, 03:32 PM
Biff's Avatar
Biff Biff is offline
Has it got bar mounted choke?
Mine stuck, ran rich
Biff
Old 02-14-2012, 03:40 PM
Biff
Very good call! That choke will do it every time. Best $13 I spent on the bike was replacing it with a traditional plunger.
Old 02-15-2012, 08:14 AM
300ec's Avatar
Biff
it is not choke - I checked
thank you Biff)
2006 txt280pro
Old 02-15-2012, 08:39 AM
300ec's Avatar
1, Has it only just started doing it?
2, How many hours on the bike?
3, Ever had a top end/rings?
4, Does it feel super soft/weak power off the bottom?
5, Like you have just lost a lot of grunt?
Thank you for your reply, Jacobi!
1, it already was when I bought the bike in the summer 2011
2, 10 - 15 hours after the change of the piston
3, I changed the piston and rings (and other parts), raised the needle one notch
4, I feel a loss power off the bottom
5, I'm sorry I do not understand what it means(((
now riding at -10 degrees Celsius (14 F) - everything works fine, the sound was gone, the bike pulls very well
the engine behaves badly when -20 degrees Celsius (-4F)
These are my jetting
Throttle valve/slide = 7
N1EF (2nd clip)
main jet 180
pilot jet 40
air screw setting - 2.5 turn out
I think I should change to smaller jets
sorry for my bad English(
2006 txt280pro
Old 02-15-2012, 11:17 AM
5, I'm sorry I do not understand what it means((( (same as 4 - loss of grunt, loss of power/torque)
N1EF (2nd clip)
main jet 180
pilot jet 40
So from this last post I understand that the bike runs well right now, and most of the time. Its only when things get colder the bike lacks power just off idle and sounds flat/dull?
Does it feel the same as when you try to take off without warming the bike up properly? Have you tried pulling the choke on when its acting up to see if it helps. Does it do behave this way every time you get to -20C?
Did you try turning the Air Screw in to richen the pilot? As it gets colder the engine will want more fuel. If it only happens when its colder out it could be telling you something.
Old 02-15-2012, 11:20 AM
thank you Biff)
Checked at the time it was acting up?
Old 02-15-2012, 11:43 AM
300ec's Avatar
1. So from this last post I understand that the bike runs well right now, and most of the time. Its only when things get colder the bike lacks power just off idle and sounds flat/dull?
2. Does it feel the same as when you try to take off without warming the bike up properly? Have you tried pulling the choke on when its acting up to see if it helps. Does it do behave this way every time you get to -20C?
3. Did you try turning the Air Screw in to richen the pilot? As it gets colder the engine will want more fuel. If it only happens when its colder out it could be telling you something.
1. Yes)
2. yes!
3. I tried to turn it counter-clockwise, not tried in a clockwise direction - it is my fault
Now try to do it in cold weather) I hope this does not happen))
Thank you, Jakobi!
2006 txt280pro
Old 02-15-2012, 11:47 AM
300ec's Avatar
as soon as power was gone, I started to check all systems
checked the choke one of the first - opened and closed his
I hope everything will be OK)
Thanx again!
2006 txt280pro
Sound in clutch....hmmm BluegassXCR Enduro Engine - 2 stroke 2 10-18-2011 01:59 PM
Engine sound decel Jakobi Enduro Engine - 2 stroke 48 07-06-2011 11:44 PM
That sound never gets old! Rick Pictures & Videos 6 05-21-2010 12:48 PM
Sound Test info help? REVERUP General Discussions & Announcements 3 11-14-2009 06:40 PM
06 EC300 - strange sound when over revved colinmc400 Enduro Intake/Carburetion - 2 stroke 5 05-02-2008 12:10 PM
