Old 09-18-2007, 05:02 AM
Gas Stu Gas Stu is offline
Default Power Valve rebuild
Hi Gents,
My power valve rattles on Idle and I want to freshen It up a little....Any Ideas on what should be replaced? Such as bearings etc...
Thanks
Old 09-18-2007, 07:44 AM
Disassemble, clean, and replace bearings. Bearings are very cheap, I replace them every top end job. Under the right side PV cover, make sure the actuator plate is in contact with the stop bolt with just a very slight(barely any) amount of preload with the engine off. If it floats over the stop it will rattle more at idle, but a small rattle is normal. This can be adjusted under the sidecover if neccessary.
Old 09-19-2007, 12:38 AM
Thanks GMP, Ill replace the bearings and give it a good cleaning and see if it helps
power valve vent ? walker1008 Enduro Engine - 2 stroke 6 01-14-2010 08:36 PM
Power valve spacer bitoman Enduro Engine - 2 stroke 7 06-15-2009 03:47 PM
Power Valve Spacer Dingo Enduro Intake/Carburetion - 2 stroke 16 01-22-2009 01:53 PM
Power valve malfunction Warwick Simpson Enduro Engine - 2 stroke 2 08-27-2008 07:10 PM
Power valve bens25au Enduro Engine - 2 stroke 2 02-09-2008 11:02 PM
