Old 07-25-2012, 04:19 AM
yeah it did feel lean as there was loads of chatter which now has gone
im happy with it now so im going to leave it alone lol with its sm wheels the front wheel has not even met the ground yet lol
Old 07-25-2012, 04:30 AM
Diggs345's Avatar
Diggs345 Diggs345 is offline
Originally Posted by gassergrant View Post
Hi Mr Diggs i got one of those RM needles from the states cost about 10 to 15 pounds
ive taken it out and put the old N1ed back in or N1EF ill check for you my bike runs better with that in ive got a 42 pilot and 178 main 1/34 on the airscrew clip pos 3
i just got fed up playing and just wanted to ride my bike is 03 300 but cant be to differant lol
hope this helps ya mate grant
Do you want to part with the rm needle
Old 07-25-2012, 06:34 AM
Diggs345's Avatar
Right my needles are here , any tips on where to start with my as2 carb in a 300 , just above sea level and around 70 degrees f
Old 07-25-2012, 07:19 AM
Which needles you working with?? My method for anything is basically the same. Needle in the middle clip. Big rich safe main jet. Slide only just open. Air screw 1.5-2 turns out. Change the pilot jet until the bike starts easily and idles well. Fine tune with Air screw. Then work on the needle clip position. Its most noticable 1/4 throtte through to 3/4 throtte. Finally dial the main in if required.
Not sure what to expect with the CCK/CEK. With the rm needle I'd suggest 42 NEDJ#3 175 as a starting point.
Old 07-25-2012, 07:25 AM
Diggs345's Avatar
Thanks pal , out of interest do you ever sleep , im just fixing my rad shouds as i snapped the lower bracket off , then its in with the z start before i play with the jetting
Old 07-25-2012, 07:49 AM
CCS537 CCS537 is offline
Originally Posted by Diggs345 View Post
If he is having the same issues as me its like the choke is on and it wont pull into the powerband without a jab of the clutch.
When i had a 40 pilot in and the needle dropped to number 1 it wasnt so bad
That's exactly what i'm talking about. Last time I rode I went with JD"s recommendation 40p 180m blue needle. Bike was way to rich up top so i'll try a 175 back in it this weekend.
Old 07-25-2012, 07:51 AM
No worries mate!
I'm a shift worker so my sleep patterns are a bit all over the shop to say the least. I sleep when I can
Old 07-25-2012, 12:54 PM
Yeah I dout I will use it PM me your details and I will get to ya. As a fellow gasser don't worry about any cash it's worth a fiver just sort us out for the postage
Grant
Old 07-25-2012, 12:58 PM
Diggs345's Avatar
Right iv put the cck in 2nd from top
175 main
42 pilot
Max tickover is about 3.5 to 4.5 turns out , do i need to go up to a 45
Old 07-25-2012, 01:04 PM
pscook's Avatar
pscook pscook is offline
175 main
42 pilot
If you are winding out the air screw, you need to decrease the pilot. You want more air/less fuel in the pilot circuit.
Phil
(New bike pending...)
EC 300 Jetting Casey97 Canada 6 05-05-2011 11:52 PM
GG jetting Gasgasogeros Enduro Intake/Carburetion - 2 stroke 0 02-21-2011 06:39 AM
04 ec 300 Jetting lordfeyr Enduro Intake/Carburetion - 2 stroke 12 01-26-2010 03:16 AM
jetting macho comacho Enduro Intake/Carburetion - 2 stroke 21 03-10-2009 03:11 AM
02 ec 250 jetting help crem55 Enduro Intake/Carburetion - 2 stroke 9 07-12-2007 01:44 PM
