#21
Holy Cow, Jake. Sarah just pointed this thread out to me- gotta have the right bushings. Glad you got that sorted.
For future reference, we keep those KYB rebuild kits in stock with both bushings, seals and dust wipers. Granted, we're not down under- and they are really nice kits, so you guys know. And usually you can take the tubes apart without screwing up the seals- and while I did just order some of the fork 'bullets' to make installing the seals easier, to this point I've put 10 years worth of seals on by hand with no problems- no tape, no plastic bags- just being careful. Get out and ride, would ya?! |
#22
![]() Quote:
I purchased one of those bullets but not keen on it. I just used the bag the seals came in with a smear of oil. All good! As for getting out and riding! The weather is perfect! Low to mid 20s. Not too dusty! I'm riding every chance I get! Cheers Jake |
#23
![]() Quote:
Through inattention, a couple of beers, and chatting while doing a fork seal job I messed up the washer that sits between the upper bushing and the oil seal. Anybody know if the washer comes with the bushing replacement kit? GG part number for the washer is BE203702509 - although on the parts diagram it shows it located between the seal and retaining clip, rather than between the upper bushing and seal? Strange? The washer is no longer usable and I want to reassamble the fork for a scheduled ride this weekend. It's a unique size and not something I can get from the local industrial supply house. Any ideas on a short-term, make-do fix? I'm gonna call my local GG shop that does EE suspension tuning in hope that he may have the washers. Man, I hate it when I do stupid stuff... |
#24
How'd you manage to do that?
#25
Pulled the dust seal off, but forgot to remove the retaining clip before I attempted to break the forks apart. Ended up hammering the washer to bits before I realized my error. Now I'm in a mad scramble to find a replacement of some sort.
#26
Sounds alcohol related to me.
#27
I did the same thing with a mates 43mm showas last weekend. Pulled down the dust seals, drained the oil, flipped the forks to drain when we went for a coffee and came back a bit eager. Luckily after a few slides that werent very effective the penny dropped. Managed to get out of it by only having the oil seal push up to the retainer clip making it a bit hard to get out.
![]() Seems I continue to learn the most when I make mistakes. |
#28
![]() Quote:
![]() Anyway ... I've got it bolted back together. The EE suspension guy (well, he is the everything guy really) at the local Gasser shop didn't have any washers, but he said that they're just a spacer that doesn't carry any load. Made up one from some ridgid plastic - an old frisbee was about the right thickness so it got sacrficed. It went together good and should get me through tomorrow's ride. I'll order a new washer/spacer and accept it for the lesson it is. Not gonna make this bonehead move again! Jason |
SKF Fork seals | orangezuk | General Discussions & Announcements | 12 | 03-14-2012 10:29 AM |
SKF Fork seals | orangezuk | Enduro Suspension | 2 | 03-10-2012 05:05 PM |
Fork Seals | Brian | Enduro Suspension | 8 | 11-17-2010 04:11 PM |
Fork seals | Iron Hide | Enduro Suspension | 2 | 02-22-2008 12:45 PM |
wp fork seals | dlwheaton06 | Enduro Suspension | 4 | 12-23-2007 06:34 AM |
