Old 08-20-2012, 11:30 AM
wakeymatt wakeymatt is offline
I think you will need to pull the flywheel and check out the sprag clutch behind there as bergerhag suggested, The gear behind the flywheel which is just visible in your picture should turn one way and bind onto the crank when turned the other. If you do a search on here you should be able to find out some more information on it. As another poster has suggested your broken shaft may have been effect rather than cause.
Yup the guy I was speaking to suggested the same thing about the broken shaft. Looking at the terrible history of these sprag clutches it would all makes sense (done plenty of reading on them). Not sure its something I want to live with when I get it sorted I will regrettably probably sell
Old 08-20-2012, 01:04 PM
Qui-gon's Avatar
Qui-gon Qui-gon is offline
This may be of some interest if you haven't seen it already:
http://www.thumpertalk.com/topic/733...r-clutch-gear/
06 Gas Gas FSE 450 USA
07 Gas Gas FSR 450 UK with motard and dirt wheels
Old 08-20-2012, 02:33 PM
Ah cheers fella, not thought of looking on thumper talk
Looks like a good fix but its an old thread and theirs not much info although I will look into it.
Cheers again !
Water issues Biff Enduro Other... 8 03-16-2011 11:00 AM
Shifting issues koka-nee Enduro Engine - 2 stroke 3 01-26-2011 09:57 AM
shiftin issues... Cruiser Enduro Engine - 2 stroke 3 11-23-2009 07:36 PM
Fuel cap issues kendunn Enduro Intake/Carburetion - 2 stroke 6 06-12-2009 03:52 PM
Kickstarter issues roostafish Enduro Engine - 2 stroke 4 07-08-2007 05:47 PM
