Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > Riding Techniques & Training
Riding Techniques & Training Increase Riding Skill, Physical and Mental Training, Weight Loss.
Old 08-31-2012, 10:27 AM
Fred1956's Avatar
Fred1956 Fred1956 is offline
Originally Posted by rod View Post
I'm only having a guess, but could it be the diameter of the wire coil in mm.
8mm does sound a bit small but 4.9 is a light spring rate.
the first set of numbers (596) is the series and the 8 & 10 are the order they are listed in the Ohlins parts catalog.
Fred Overstreet
2010 EC250 SixDays
2006 GasGas TXT 280 Pro
Old 08-31-2012, 03:40 PM
Whats the series number for the TTX spring?
Old 08-31-2012, 06:17 PM
Fred1956's Avatar
06310. & a 5.8 is 13 in the catalog -06310-13/58
Fred Overstreet
2010 EC250 SixDays
Old 08-31-2012, 07:31 PM
How about a 5.4? Rod was asking me.
Old 08-31-2012, 09:45 PM
Fred1956's Avatar
Should be a 06310-11/54 but I'm doing that from memory (58=13 56=12 54 should be 11)
Fred Overstreet
2010 EC250 SixDays
Old 09-04-2012, 05:10 AM
rod rod is offline
Yep, your spot on as i've recently found out.
Old 09-04-2012, 05:13 AM
Did you end up sourcing one locally Rod?
Old 01-13-2013, 09:53 AM
Caravan Monster's Avatar
The rear shock spring on my bike has the number 00580 09/50 L235 (Ohlins / '06 EC200) Would I be correct in understanding this to indicate a 50Nm spring ?
I'm around 100kg / 220lb ready to ride, would a 52 or 54Nm spring be more appropriate ?
The set up on this bike is a bit strange - there was only 7mm preload on the spring, yet the race sag is only 85mm with my weight on board. I double checked this several times because it looked 'wrong', but got the same results.
'00 Montesa Cota 315R
'13 Husaberg TE 300
Old 01-13-2013, 12:51 PM
Anders Anders is online now
Yes, the 06 200 has 50nm spring as std. I am about the same weight as you and use a 5.6 kg spring from Enduro Engineering. I use 0.45 kg springs in the forks.
Sent from my OMNIA7 using Board Express
Old 01-14-2013, 02:45 PM
Thanks Anders, I thought it was too soft. I'll check the springs too because they do dive.
'13 Husaberg TE 300
Fork bleeders for Ohlin forks. Porkyblader Enduro Suspension 1 11-15-2010 11:36 PM
2003 EC 200 Ohlin rear spring lankydoug Enduro Suspension 8 08-30-2010 04:35 PM
