subframe surgery?
Has anyone tried cutting the suframe down on a '09-'11 to lower the seat height? I am a little vertically challenged could use an inch or so of height reduction. I know that I can send my suspension off and have it lowered but the cost and the fact that you loose travel is holding me back. I have an '11 300 six days with the 45 mm zokes and ohlins shock. It looks to me like I could cut out a section of the down tube and reweld it I just don't know how much I can cut out before the tire hits And I don't want to end up with a chopper and be slideing off the back.
Thanks.
2011 300 Six Days Plated-Gnarly Pipe Tublis-Pivot pegs-P3 guard Custom billet bits |
JMO but I would avoid this if possible. It could raise all kinds of fit issues with the silencer, seat, air boot, etc. Not specifically on a GG but in general from what I've seen.
I've been thinking of the very same thing. This will help you determine if its possible:
-Remove the lower subframe bolts and loosen the top ones. -now you can pivot the subframe up and down. You can check the seat, airbox, shock clearance and pipe for clearance and binding issues. I did this when I first got the bike and it looked like an inch at the rear of the seat would be doable. This won't make it feel much lower, because most of the loss is at the rear of the seat since the pivot is up front. However, it would make swinging a leg up and over the bike infinitely easier. Especially from the downhill side of the bike. If you pursue this, there are a couple of options. Obviously you can cut, shorten, and re-weld the lower arms of the subframe. But I thought about just ovaling the bolt holes in the subframe. The one problem I saw was fitment issues with the silencer to the new subframe location. If about 5/8" is cut off the end of the pipe and silencer, they can be connected by about a 3.5" section of heavy duty heater hose without being sleeved together. This would give some leeway to line things up. I just happen to be running this setup to cut down on vibration. Like I said, I didn't end up doing any modding, but I'm thinking about revisiting this.
Newest Spanish Girlfriend: 2011 300 Six Days My Daughter is a U.S. Marine |
http://www.ebay.co.uk/itm/Gas-Gas-EC...item3ccba0e6f3
just install theese, and lower the fork in the clamps, cutting in to your subframe will only destroy the frame..
Henrik Schmidt Faster, Faster!! Until the Thrill of Speed, Overcomes the Fear of Death.. Team YamaGas Racing. http://bricksite.com/teamyamagasracing |
Might try cutting down the seat foam if you haven't already
I tried cutting a subframe before on an older GG and it was too "off" just too much work and did not really gain any significant drip in height for all the work.. I cut the seat foams down now and use different length links. I have 123's? on my 97 which was stock and when swapped out on my 03 it dropped that a bit.. and I had 126's but it dropped it a bit much for me. I think I ended up with 124's on that bike for a while. I sold it with the stock 122's? The longer links made the rear feel slightly more progressive and slightly softer. Which was good for me. I had a 5.4? rear spring in and it was a bit harsh at times and that calmed it down nice without a revalve. I'm looking at getting a z-link for my stupid pumpkin if I keep it.. would like to drop it down just a hair.. touching the ground would be so very nice..
Steve 16 Beta 350rr 04 KTM 525 sx/exc gone 03 KTM 625 sxc-rehab unit-did its job and now gone 03 GG 250 ec-gone 97 GG 250 ec Gone |
Carpal Tunnel Release Surgery | Boomhauer | Injury & Recovery | 62 | 05-17-2010 05:25 PM |
Subframe | lordfeyr | Enduro Chassis & Body | 2 | 07-16-2009 07:58 PM |
subframe ? | Loosenut | Enduro Chassis & Body | 3 | 09-13-2008 12:43 PM |
Laser eye surgery "monovision" | Mark Tracy | Injury & Recovery | 6 | 08-04-2006 10:46 AM |
