#131
N3Cx is half a clip leaner than the N3Ex
N3CH#1 is leaner than N3EH#1 by half a clips difference. |
#132
ok clear, and since i ride at a slightly higher altitude to you then i should be able to use the same jets as you and make up the difference in altitude with the slightly leaner needle and air screw
#133
Lots and lots of variables come into play. Individual engine characteristics, Temp, Altitude.
What was your jetting previously that isnt working now? What symptoms is your bike showing? Rich/Lean where? At what throttle positions? What has changed environmentally? For example: My bike was tuned 38 N3EG #1 175 100-1000M 30C 80%+ Humidity - Slight burble off idle It has now started to cool off into winter. Temps dropping between 5 - 10C. The rain has also cleared up with RH between 50-70%. By changing needles I leaned the lower burble out. G diameter - H diameter. I also effectively richened the needle position by half a clip. New setup 38 N3CH #2 175 100-1000M 26C 55%RH |
#134
Have you checked the float height yet? That is the first thing that needs to be addressed.
#135
Yes first thing I will do is set the float. Then disconnect the choke
It was almost fine before. 175 40 n3eh #2 at between 600-1300m but it always had a bit of a sPlutter going from slow to wfo which is why I think the 172 main should be better. There was often a bit of spooge out the exhaust I also think with the fan I can afford to go slightly leaner
#136
As long as you just make one change at a time, one step at a time, you won't go too far wrong. I know of one person here in Aus who is running a 168 Main.
Throw the 172 in and ride it down the street. You'll almost immediately know if its got better or worse. |
#137
plug chop question
thinking of giving this plug chop thing a test, now GG recommends the BR8EG but i do not want to waste a $15 plugs so if i use the BR8ES which is about $5 to get the jetting right will it then be off if i move back to EG?
#138
Some people say to use a fresh plug for each chop, but I have found that even using the same plug you will notice differences between whats too rich and too lean. If its running too lean or hot it will burn off any carbon. If its running too rich you'll see excess.
I have read about the super keen using a fresh plug and cutting the threading back to inspect the porcelain area. I just look in there using a mini torch. |
#139
Theres no difference in effective jetting between an ES and an EG, it will be fine to get the jetting right with an ES then swap back. Wasting $15 on a plug that you use once then replace with a fresh one is silly, even if you keep it as a spare.
#140
jet with cheap plugs. they're usually easier to read too....
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com |
2010 250 EC Jetting. | enduro1 | Enduro Intake/Carburetion - 2 stroke | 13 | 08-19-2010 05:56 PM |
2010 Sachs fork factory compression stack specs(ec300) | bergerhag | Enduro Suspension | 9 | 07-01-2010 11:18 PM |
2010 EC250 Jetting | WTEC | Enduro Intake/Carburetion - 2 stroke | 1 | 03-26-2010 09:41 AM |
jetting for new 300 racing 2010 | fabulous furry | Enduro Intake/Carburetion - 2 stroke | 9 | 08-11-2009 09:28 AM |
04 EC300 jetting? | DWreck | Enduro Intake/Carburetion - 2 stroke | 13 | 11-26-2006 08:12 PM |
