#131
Those are the right ones. I keep a bag of these in the tool box. I have had to change them several times. About whenever you get vibration/rattle, its usually the orings. I have used so many of these that I need to order a new bag of them.
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
#132
I ordered 4 of the KTM o-rings after reading several on here used them but wouldn't mind having a few more extras so I don't run out. Thanks for the tip about McMaster-Carr.
-Mike 2009 Beta Evo 300 4T - 1982 Suzuki PE175 |
#133
I like to slather hi-temp silicone on my pipes for good measure.
All healed up, and ready to burn some fat. |
#134
I have a hypothetical question... What would happen if you kept the PV closed all the time.
#135
The engine wouldn't flow very well and would feel rather restricted with no real upper rpm.
#136
The pivot bolt broke off one of our 300s and it ran fine on the bottom end and ok in the mid range but it had a significant reduction in top end power.
#137
Hi, is there a trick to get the right side case off so I can adjust my power valve, I've taken every bolt off around the outside as well as the clutch cover and water pump cover and impeller, have been gently tapping case with rubber hammer but the bloody thing won't budge, rock solid, thanks
#138
Sounds like the dowls are stuck, continue to gently tap around the cover.
It may take a while. but you will get it off.best of luck.
'12 XC 200 TTX Sold '15 XC 250E Sale pending |
#139
Good Riding and Wrenching to You! Jim .
Jim Cook Smackover Racing Team LAGNAF '11 Gas Gas EC250 (primary ride) '06 Gas Gas DE300 2004 Gas Gas TXT300 Pro '94 Husaberg FE350 '86 Yamaha IT200 '86 Honda TRL200 Reflex '04 KTM 525EXC (soon to be dual sported) Several others, including project bikes, Deb's bike, and a fleet of grandkids' bikes Let's go riding! http://www.jebruns.com/Wudi19/wudi19.html http://www.ahrma.org/schedules-results/cross-country/ |
#140
Same as Jim. I just grease the gaskets and they seem to break away quite cleanly when required.
The dowel down near the water pump will likely be the one thats causing the issues. A little heat, some penetrating fluids, and a mallet might get things moving in the right direction. |
Low down / tickover issue HELP | stevehipkiss | Enduro Intake/Carburetion - 2 stroke | 9 | 02-14-2011 09:03 AM |
jetting - idle issue. | stainlesscycle | Enduro Intake/Carburetion - 2 stroke | 7 | 12-30-2009 02:47 AM |
clutch issue | boostedte37 | General Discussions & Announcements | 2 | 11-09-2009 06:58 PM |
ec 400 gearbox issue | Paul Somerville | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 09-05-2009 10:17 AM |
PowerValve Issue- Take A look at this Picture | alexpp | Enduro Engine - 2 stroke | 13 | 04-12-2009 12:13 AM |
