#11
What the heck, try to find an American bearing just for fun
#12
Is there a special type of wrench to get to the cylinder nuts that are located in the powervalve assembly? Its a 13mm but everything I have is to big to get in there.
#13
Buy another 13mm box wrench and relieve the outer edge on your bench grinder enough so it fits. The nuts are not so tight as to create a problem. Put it in the "special tools" drawer of your tool box.
#14
That was my next move, thanks. Now for the next question, anybody have experience getting the counter balancer out. Is the nut reverse threaded, because I cant it to budge.
#15
Not sure, ping Cruiser, he has a '97 and has had it apart. If its geared to the crank, it spins in the opposite direction (CCW looking at the primary side). Considering this, logic would tell me its a standard direction thread like the clutch basket. The crank pinon nut I can tell you for sure is reverse thread.
#16
OK, I am giving up on trying to remove the counter balancer nut peacefully. It is on there to stay! Anything wrong with cutting it with a wheel and breaking the nut off? I have done this method before just not on internal motor parts. Cant see the red circle to well, but this is the nut I speak of. It's the only thing that stands between me and splitting the cases!!!
#17
You may have to heat the nut to loosen the locktite.
otherwise, cut it off. |
3 piece sprocket | geraldh | Enduro Chassis & Body | 5 | 10-05-2009 07:10 AM |
large gas tank | baker | Enduro Engine - 2 stroke | 1 | 12-10-2008 04:25 PM |
Ignition drain hole. | roostafish | Enduro Engine - 2 stroke | 3 | 11-28-2008 08:08 PM |
Large Fuel Tank | kim | Enduro Engine 4 stroke (including EFI & Exhaust) | 6 | 05-15-2008 03:43 PM |
Mothers Metal Polish | Boomhauer | Enduro Product Reviews | 3 | 06-23-2007 07:02 AM |
