#11
Wow! Nice feedbacks guys, this is my second gasser. Its a slightly used 2015 i bought, Think it has 40h on the Clock. I see mine has the ajp clutch system so i will hold my thumbs it doesnt brake on me.
The jetting seems to be very good so i don't Think I will leave it for now. I have now greased the linkage so thats fixed. And also bought a lithium battery. And removed the gummy plug in the air filter box. Overall the bike seems to be very neat, i like the new oil level glass and brake pedal and shifter. It also seems to be a Little bit lower and more narrow around the tank then my provius gasser (2013). Im very pleased with the respond i got from this forum! Sucks i didnt find it earlier. I Live in Finland. Its Winter here now so i cant really test it out properly becouse its fucking Cold. But in a few months it will be spring I will ride a mix of endurocross/mx/singeltrack, hope it gonna rock! |
#14
Stock up on kickstart shafts
2011 Gasgas EC200, 1966 BSA 350 scrambles, 1972 Montesa cota 247 |
#16
I have nearly 70hrs on my '15' EC300 now and have noticed the following:
As mentioned the side stand comes loose. Use locktite. While on locktite put it on the sub-frame bolts. I have lost plenty of those! I have changed my jetting as per posts on this forum. Do a quick search you will find plenty of info. Both of my radiators split the cores. I now run Ebay specials and have not had any issues. If your after some extra grunt get the squish done. It makes a world of difference. I have also had an oval bore done on the carb. I found the forks extremely harsh and I'm 75kg butt naked. So I now run 3 weight oil in the forks and have the comp clickers nearly all the way soft. I have nearly no preload on the PFP also. The shock is great. I have it reasonably soft comp but it works really well for me. I adjusted it until I was getting tire marks on the mudguard for normal riding conditions (whoops, jumps etc.) then I went 2 clicks harder. Everything else on the bike works fine. I have not had the said clutch issues etc. |
#17
Yes the forks feel harsh initially.i found there was an improvement after 70/80hrs from new,and slowing the rebound(increasing reb damping) by at least 6clicks helped.(13 200)
Keep an eye on the stock chainslider/guide,replaced mine with tmd around 100hrs
2013 ec200r |
#18
Anything else guys? im just about to pick up my 15 ec250. ?????
any new updates on crossovers or upgrades to do? |
#19
Try and get your hands on an earlier model shaft if you can. I've got a mate who has snapped two new kickstart shafts in a month while his e-start has been playing up.
The new shaft has for some reason been produced with a reduction in diameter and a groove at the point of most stress. Apparently the 16's have this new shaft as well.
#20
One thing that I have done to mine is to replace the OEM footpegs with Talon ones. They sit a few mm lower and offer much better grip. I had some problems with slipping off the pegs during winter with the OEM type.
Anders "So you know, that you're over the hill when your mind makes a promise that your body can't fill" (Little Feat: Old Folks Boogie) 2015 EC200 Racing: TE bars, Rekluse Core Exp 3.0, 38mm Lectron & Ohlins S3 steering damper 2006 EC200: 2011 plastics, Rekluse Z-Start, revalved KYB forks & Scotts steering damper 1998 Bimota Supermono 1986 Duc Mille S2 1975 Guzzi sidecar hack 1961 Morini Corsaro 125 etc |
Head mods | Ls1jy | Enduro Engine - 2 stroke | 23 | 12-31-2012 02:37 PM |
'12 airbox mods? | GMP | Enduro Intake/Carburetion - 2 stroke | 10 | 07-12-2012 09:50 PM |
What cool mods have you done? | einsteingarage | General Discussions & Announcements | 8 | 05-10-2011 05:21 PM |
Gas Gas mods | pevs | Suggestion Box | 6 | 01-26-2010 12:22 PM |
