#11
The Doma pipe is nearly identical to the stock GG pipe. The LTR power valve cover helps low end to a moderate extent. No effect once the power valve is open. Before you start spending big dollars get your jetting set up correctly. For starters read what others have run for jetting in the jetting section. Try some of the common settings and see if they work for you. LTR jetting works well for many people.
Eric K '06 GasGas EC300 '01 GasGas XC300 |
#12
Prolly reeds. You getting a ratty sound instead of on-the-pipe hp?
There's only brrr-rat, instead of braaaaa? My bros. 04 EC has the same lack of upper mid to top hp. He's running a Doma, LTR jetting and PV cover. PV's are working. Gonna slap some new reeds in this afternoon. He also machined the head down aboot .015" to correct previous uneven hack job! Squish gap should end up over .060". |
#13
Badda-bing...reeds, reeds, reeds. They were wasted. Check them
immediately. Shockingly, the RAD Valve bodies reed contact surface was extremely pited, it required a rough file, fine file and finaly a lapping stone! Now she pulls and pulls up top after installing some Boyesen ProLites and a squish gap of .053". Compression is still a low 130lbs.! but bro. already planed for a piston anywho. It's my ride for Saturday, so I'll treat it to high dez goat trails and hill climbs. I'm gonna be sore, as I'm used to KTM 200 power. |
2001 EC300 won't idle - can't get jetting right | bexi | Enduro Intake/Carburetion - 2 stroke | 16 | 03-04-2010 10:30 PM |
07 Plastics on 2001 ec300 | johns2394 | Enduro Chassis & Body | 5 | 04-04-2009 07:17 PM |
Gas Gas EC300 2001 Supermoto maybe | johns2394 | Enduro Chassis & Body | 12 | 01-29-2009 07:58 AM |
2000 XC250 CDI for a 2001 UK EC300 | krazy | Enduro Electrical & Wiring | 1 | 09-14-2008 04:58 PM |
