Old 05-18-2012, 05:03 PM
bones150 bones150 is offline
Thanks guys. Put blue spings and anti squeal kit in and feels better around shop. The one thing is if I pull clutch in , in gear and rev bike up it wants to surge ahead. does not fully engage. not a real problem unless you want to do mx starts.
Old 05-18-2012, 05:38 PM
jeffs2200 jeffs2200 is offline
I personally run the red springs in the EXP ring. These give the fastest, hardest hookup. If the clutch does not have full override at all rpms as you describe then something is not right.
Make sure you have the .040" steel installed in the clutch pack at the bottom just on top of the Rekluse hub. If you did not use the .040" plate the clutch pak will be too thick and you will get some of the symptoms you describe.
Old 05-18-2012, 05:42 PM
thumperrider1 thumperrider1 is offline
Also make sure there is no air in the hydraulic system.
2018 XC300
Old 05-18-2012, 08:07 PM
whitebear whitebear is offline
Installing Rekluse clutch basket also takes most of noise away, unless you are 2-3 gears too high.
Old 05-18-2012, 10:36 PM
rgranger's Avatar
rgranger rgranger is offline
i ordered the rekluse basket today Sounds like i made a good call for a change
Rob Granger / Katy, TX EC300
Breaking more things by 8:00AM than most people break all day.
Old 05-22-2012, 10:19 PM
Gasaholic Gasaholic is offline
Default rekluse exp
I run 6 red springs anti-chatter kit (o-rings), one turn plus two ticks and rotella T oil , no chatter loving it!!! 2011 EC300
ok I installed the orings blue springs 1 3 ticks and got rid og the squak. raced 2 races and got a second and a first vet expert. worked well.
Old 05-23-2012, 05:34 AM
GasGas's Avatar
GasGas GasGas is offline
Do you guys have a part number for the Rekluse clutch basket?
2018 EC 300
Suspension experts please help mikemoto Enduro Suspension 22 03-08-2012 02:46 PM
Calling jetting experts! Todd5774 Enduro Intake/Carburetion - 2 stroke 19 02-23-2012 11:33 PM
Marzocchi experts - help with 08' EC250. nick790 Enduro Suspension 1 05-09-2009 02:41 PM
