#11
ok, problem solved. set the air screw to 1 turn out, problem was much better. played around with it for an hour or so and found 1 and 3/4 of a turn out to be the best setting. bike was very responsive from no nearly no revs in second, i had a few bails just getting used to the new responsiveness.
thanks for the help everyone, i wouldnt have associated this problem with jetting, but glad its sorted |
#12
You don't know the difference between running rich and lean? Put a 195 main in and go for a run down the street. The bike should run ok on pilot then chug and splutter and not rev out...... this is how it feels when a bike runs rich. Now if you dare , drop the main to a 165 and do the same run and see how it feels... If it pings or feels very responsive work up from there. Ideally you will get a feeling for it as I did . So long as you interpret the bike and don't rev the ring out of it you will be ok. It is a pain in the arse changing main jets but a quick and easy way to get a ballpark on what feels right. I have a 300 and was running a 180 on the 4th clip from bottom. Changed from 32:1 to 50:1 fuel mixture( which I recommend), Dropped the clip position to middle and then puit a 200 main in. Ran crappy. Put a 170 in , ran awesome but thought to be safe I would put the 180 in. Still runs great although not as snappy, but for me it is better to be a little richer. Try it and you will see. Good luck. Mark |
#13
the top end is rich i think. lots of spooge, or have i crossed wires associating spooge with richness? theres too much fuel for the pipe temp to burn the excess, meaning spooge? i havent changed any jets. still have a 40 pilot. just the air screw was tweaked. plus, i dont have jets to africa to test. sorry, so cant do those tests. |
#14
Spooge and richness is not linked as far as I know. If you can borrow the jets It would help you. What fuel are you running at what mixture? Cheers Mark |
#15
iv read stuff about spooge, it could be the oil mix, but it only happens when im on the main jet lots, not during a tight forest ride. ill try and source some jets from some motox mates, and do the test. thanks, dale |
#16
I still would suggest borrowing the main jets to try.... thats what I did. They were only about ten buck to buy I reckon but a mate had a whole stack which I used to check. All the best Mark. |
VORC Extreme Sprint -Australia | Keg | Ride Reports | 0 | 09-12-2010 07:35 PM |
Canada's first Extreme Enduro: Xtinction | SpeedyManiac | Pictures & Videos | 6 | 08-29-2010 05:55 AM |
Enduro Extreme Genova 18-02-2007 | gasgasman | Pictures & Videos | 1 | 04-02-2007 09:04 AM |
extreme heat? | crazjarhead | Enduro Engine - 2 stroke | 6 | 08-24-2006 08:03 AM |
Hancock WEC Extreme Test Helmet Cam Videos | Berkyboy | Pictures & Videos | 3 | 08-03-2006 01:33 PM |
