#11
Thanks for the offer, 2-Wheels.
I fought the heat and got up at 4am Saturday and again on Sunday to ride in 90F temps until about 8am. On Saturday I took a buddy who has about 50 pounds on me. He has sold his KTM300 so I loaned him my WR50. I forgot to bring my tire pump so I was riding with 7 PSI of air front and rear, so I had to take it easy due to our sharp rocks. I had some rocky single track and a selection of whoops (gravel sand, sugar sand, and hard pack). The shock and forks were both set in the middle of the range. I noticed they were firm, but compliant, and a little busy, especially when my buddy got on it. I slowed the shock damping ten clicks (about ten from full in) and that tamed it 80%. I clicked it in another 5-clicks and it behaved fairly well. I left the Ohlin's compression setting(s) along. Given the damping/compression circuit mixing of the Ohlins 888, I think a revalve is in my future. My buddy said he was amazed that the forks rolled over volleyball-sized rocks well, but it was jouncy in the small stuff. For me, it was the opposite. I didn't feel the small stuff, and the bigger stuff was handled well. I backed off the compression five clicks to 20-out. I noticed that when I came off a whoop jump face, the forks extended with a thunk (just as my WR does). Some bikes do, some don't. I'd like to get that fixed. Those Metzler ISDE tires (with 14 hours on them), really held the bike back. The tires were no match for the brakes, and their behavior in bumpy corners didn't allow me to go fast enough to test the boingers in those situations. It looks like the forks were raised about 5mm from the fork nut. How this affected the suspension and handling is unclear to me, but I noticed that the front was just a bit twitchy (un GasGas-like) and would've benefited from mounting my Scotts (waiting for the BRP underbar mount). So, the suspension isn't too bad. I could race and ride this at my C+ pace quite well. However, I'm still thinking about upping the springs some (5.4/.44) and plushing the boingers and adding some rebound damping. |
#12
I am taking it to the suspender guy tomorrow.
Given me at 185 (buck naked, with a good chance of making it to 175 in the coming months), what are the recommended spring rates for me? Stock is .42/5.2 Is .44/5.4 reasoanable or should I consider .46/5.6 ? |
#13
My tuner (futureshoxs.com) called Ohlins. Based on my weight and the Gasser's particulars, they recommended a 5.4. He is going to revalve both ends to be super plush over rocks while bumping up the rebound damping.
He is suggesting that I hold off on new fork springs until I ride it to see how it takes G-outs and handles exit turns from sand washes. One curve ball, I showed him my LTR-massaged O-888 shock which supposedly had a 5.4 spring mounted to it. All the markings were rubbed off but the coil diameter was actually about 0.2mm thinner than the marked 5.2 on the 2011. |
#14
I took the bike out to ride some real Flagstaff rocks. My tuner did minimal work to the system, just poked around to see if anything was amiss and put a new spring (5.4) on the shock. Total sag is about 104-ish.
I was pinging all over the place, so I went to the clickers. On the forks I had the rebound all the way in and the compression all the way out. PFP is supposedly at zero. Fork was still stiff and boingy, only slightly less. A local tuner got on the bike and bounced it around and said, "I see Marzocchi hasn't changed its rebound philosophy -- ain't none." He looked at the dirt line on the .42nm-sprung fork which had just a few inches of travel and compared it to his KTM which had several inches of travel. "You're not using much of the stroke on these." --- and, it clunks on extension. The shock now had a 5.4nm spring on it. Similar problems as with the forks. I backed the compression (hi & lo) all the way out to get some travel. I also dialed in the rebound to 5-out, then all the way in to get it to slow down, knowing that the cross-talk would become an issue. So, what is the shim set up should a 180-185 guy use for C/B speed rocks ? |
#15
Bouncing twin chamber forks doesn't tell you the whole story, the cartridge pressure rises dramatically as the damper rod speed increases.rebound damping has the same effect as the rod is fully displacing oil in the cartridge towards full travel the pressure increase so rebound damping deep in the stroke is different to a few inches of bouncing.
Oz Current. 2015 ec300r estart, 98 RM 125 2013 Ec300r 2011 Ec300e 2009 Husky TE310 1982 XR500 Honda 1981 KE100 Kawasaki 1978 GT80 Yamaha |
#16
Gotcha. We were looking at the stroke mark after a 30-mile trail ride. The rebound comment was done after bouncing. I could feel all the madness during the ride. I am not sure if he changed the cartridge oil.
I re-read the big 48mm Zokes thread. Interesting about the similarities. Strange that there is little mention of stack modifications. |
#17
My tuner talked to Alan to get things sorted out.
The key was working on the proper fork oil level for a B-rock-racer who rides at an upper C-pace. I am quite a challenge. The chunk sound on full extension is now gone, and the front end really "springs" to life confidently over whoops. The rebound was left alone, but they added a second bleed shim to the compression stack. It was compliant in rocks, but a little divey under hard braking. I tuned out the diviness to my liking with two full turns in of compression. That was a trade-off in the rocks, however and I backed it off one turn. I might see what the PFP adjustment does for it as well. Upping the fork's rebound damping clickers from 20-out to 15-out gave it a nice, nap-of-the-earth floaty feeling. The shock rebound damping was too my liking as set. I might take out some slow-speed compression. Not sure about high-speed, just yet. Last edited by AZRickD; 07-27-2013 at 11:17 PM. |
#18
So where did you end up on the springs Rick?
With the TTX at both ends on my 2010R I'm running .46 up front, and 5.4 rear and can bottom both when running the clickers soft or g-ing out. In saying that though the overall ride on those springs is quite firm and the bike sits up well in the stroke. I wouldn't call it plush, but its very compliant. I'm only 165lbs nudey, but carry the heaviest toolroll ever.. I'd be between 200-210lbs with all the gear, tools, fluids, and a bit of sweat and mud caked on. |
#19
I have upped to 5.4 in back and kept the fork's stock for .42s for now. The cartridges are untouched. Alan said they are tricky beasts.
My tuner related that Alan said that's what he's done (and is in my weight range and likely much faster). I'll ride it a few times to see if I need to go up one in the front. The soft valving in front might require more spring to keep it in the stroke. Or maybe the PFP can be used. I'll read up. Alan says he has been waiting for a long time for those stubby PFP springs in a lighter variety. He has springs for one titch stiffer but is still waiting on the one titch wimpier. |
#20
I took the forks back to the tuner last week to add more rebound damping. He removed a bleed shim in the stack. I rode it on some bumpiness and it feels pretty good.
Wanted: Stuff for my New-2-Me EC250 2011 Race | AZRickD | Parts | 11 | 06-26-2013 06:01 PM |
Today's powervalve thread - loose bolt screws race | motogroove | Enduro Engine - 2 stroke | 3 | 07-29-2011 04:33 PM |
2010 Sach suspension thread for noobs | forgiven | Enduro Suspension | 8 | 02-03-2011 06:37 PM |
Race Tech Suspension???????? | Wicitup | Enduro Suspension | 9 | 11-25-2007 04:55 PM |
FAQ in suspension thread?? | Link | Enduro Suspension | 6 | 10-04-2007 05:47 PM |
