#11
If i turn it all the way up then when it gets to the end it makes 2 clicks. Then when when turning it down again only 2 clicks from topand then it is just smooth turning until it reaches the end.
#12
Sent from my SGH-T999L using Tapatalk |
#13
Put the shock in. Played with the rebound knob all the way up and all the way down. Definitely a difference between the full on and off. Only 4 clocks at end though.
What is the correct torque settings for top and bottom bolt of the shock. 2004 200ec. i used 60 nm for top and 26nm for the bottom as per a table i found on the site. Manual says 39nm, dose not specify top or bottom. Just tried again now. Compressed the shock a good few times. Turned the rebound to the bottom. Compressed again. Turned until I got a click. Now I have turned it up to 15 clicks. Will check if it will click more Sent from my GT-I8190 using Tapatalk Last edited by kyton; 06-01-2014 at 02:11 PM. |
#14
#15
Never missed it.
Sent from my GT-I8190 using Tapatalk |
Problem IDing/Baselining Ohlins Shock | GasGasDreamer | Enduro Suspension | 3 | 03-31-2015 03:18 PM |
07 ec250 will 05 ohlins rear shock fit | gasgasandrew | Enduro Suspension | 1 | 01-22-2010 04:39 PM |
Ohlins Rear Shock oil change and regassing | kim | Enduro Suspension | 9 | 02-02-2008 03:07 PM |
ohlins rear shock broken! | tommo | Enduro Suspension | 4 | 05-07-2007 07:15 AM |
Suspension fastener and shock problem | sn22 | Enduro Suspension | 1 | 09-02-2006 12:45 PM |
