#11
1L loss is totally worth it. |
#12
No, it was not over dramatic. I take my tank off after every race or after every few rides for cleaning and maintenance. It was a deal breaker, if I had to fight with it the way I had to with the 2012 tank.
Mechanical failures happen and I can deal with those because I ride fairly hard and am likely the cause of those, but when the bike would not even come apart and go together as it was designed, I was ticked. The bolt hole in the tank was 6mm off from the hole in the frame. I pried with levers and heated it up to no avail. Clay and GoFasters came to aid and I have a '13 tank and have had ZERO problems since. |
#14
ditto: I carry some spare bolts and washers now.
Rob Granger / Katy, TX EC300 Breaking more things by 8:00AM than most people break all day. |
#15
Jp is right. Although it sounds like an annoyance its a big problem. You can't line up the mounting hole and the tank does not sit square in the frame. If the tank does not fit, nothing else fits. I had to pull a vacuum on mine to refit it, and have not removed it since. I too just received a warranty tank ('13), Clay and Mark have been great with support.
#16
Our ethanol plays hell with some plastics and the '12 tank would swell so the tank was tight and the hole in the front of the tank would not line up with the hole. The were changes in the in the '13 plastic and the tank was made a tad smaller so that if it did swell, the bolt hole would line up.
You may read this and ask why plastic was used on the '12s that would be effected by fuel with ethanol. When I was over there last summer, the production manager was telling me and my nephew that the week before their tank supplier had called and said we are out of business as of today. They had to scramble to find someone to make tanks and they did not have experience with ethanol fuel. We have been warranting '12 tanks that have swelled and will no longer fit. Fletch....I can assure you your dealer did not switch tanks on you. I'm sure the bolt was not tightened sufficiently and fell out. |
#17
Looks like the 12 tank for sure holds more then 2.7 gall as I put that much in today and was room for app a quart or so more of fuel.
#19
I have the same bike, same tank on my 12'. And yes it fits tight, but I wouldn't call it a "deal breaker" considering how great the rest of the bike is.
#20
I agree and does it really fit that tight???????????????
2012 vs. 2013 | singletracker | General Discussions & Announcements | 67 | 12-18-2012 06:34 PM |
Frames 2012 and 2013 | jaysktms | Enduro Chassis & Body | 21 | 12-02-2012 06:54 PM |
New 2012 or wait for 2013 | Diggs345 | General Discussions & Announcements | 76 | 06-25-2012 05:32 PM |
