#11
Options... that's kind of how I'm looking at it. The triples are the same width but I still need to verify the GG bearings will work out.
I honestly think the Beta is a little "knifey" at 20mm & 35mm but very stable in the straights which makes sense having more trail. When I mount up the KYBs I'll use the inserts for 24mm on the clamps so I'll net +1 (24+32). One bike will end up with the TTX and the other with the KYB. At the moment, the Beta is my race bike so it'll get the forks that suit it best. That may change I read some of your KYB conversion, if you also have the 2012 KYBs you might need to go with the longer WR axle to get enough bite for the right fork lug. I did.
Walt Kidd 2011 EC 250 2011 NAMBOTIN 2015 Beta 300 2016 Beta 300RE 2016 Beta 350RE |
#12
Cheers for the info.
90% of what I ride, and where I ride more aggressively is single track. I'm hoping it works out. Generally don't mind a bike that requires active riding. When do you plan to have yours all implemented? Probably a month or more before I'll have a chance to test. |
#13
Have all the parts in hand finally, but the weather and work schedule haven't been cooperating. Hope to test the setups this week, but should easily get on it by early next week. I'll post up how it goes.
#14
Look forward to hearing your impressions.
Nambotin triple clamp....help | redrider | Enduro Chassis & Body | 4 | 03-12-2014 12:59 PM |
Total offset of GG front ends? Triple clamp + lug offset | ghill | Enduro Chassis & Body | 0 | 05-02-2012 08:03 PM |
Triple clamp offset? | Harry | Enduro Chassis & Body | 4 | 09-08-2011 04:45 PM |
Triple clamp offset??? | Keg | Enduro Suspension | 3 | 10-08-2009 07:48 PM |
