Old 06-21-2014, 12:16 AM
Banned
I would do a compression check and pull the cylinder. And measure the ring gap.
Sent from my SGH-T999L using Tapatalk
Old 06-24-2014, 07:50 PM
farmerj's Avatar
farmerj farmerj is offline
So a day or two ago the bike started, ran for a few minutes and then died (as it has done several times) But while it was running I was able to ride it, and remember that it had acted this way when the problem started...it ran fine at low throttle openings, but over half-throttle, it sputters and bogs.
Does this give us any clues?
FWIW, it seems like an electrical problem, to me. But I could be wrong. It also seems like when the thing heats up a bit, then whatever the problem is gets worse and kills the engine.
Old 06-24-2014, 08:21 PM
wa_ndro wa_ndro is offline
so ur definitely getting fuel if its running then...
I was going to suggest you had adjusted the float too far and weren't getting enough fuel. I have done this before.
Easy to check - just drop the bowl and turn the fuel on and play with the float.
Old 06-25-2014, 09:55 AM
Neil E. Neil E. is offline
The float would have to be adjusted very low to have an effect at half throttle. Lack of flow is usually more noticeable above 3/4 throttle.
I would tend to think this is electrical which could be any of the following: connections / stator exciter coil / ignition coil / CDI.
2011 EC250E
Old 06-25-2014, 10:36 AM
iamovru's Avatar
iamovru iamovru is offline
Thanks guys, I appreciate it! I had pulled the pilot & main jets and they looked fine, no gunk in the carb, but I'm thinking you're right about the need for a good cleaning and can do a pilot jet replacement. Will check some of the other items mentioned and keep on the path!
Jeff
You really cant tell with jets by a visual inspection. I had the same issue with my KTM 450EXC and I replaced the pilot and it started right up. If gas has been sitting in there for a year, I would bet that is one of your problems.
15 Beta 300RR Race
Sold KTM 450EXC now moving over to RED! Looks like I found the right bike. Thanks REVERUP!
2011 GasGas EC300 "Stolen By A Scum Bag"
2009 450EXC Sold to Rapid Dog EURO Factory Anti-Hop slipper clutch, GPR V4, Akropovic Full Ti Exhaust, 2013 suspension and wheels.
2009 300XC
2005 525 MXC
2000 WR 400
1996 XR 600
1987 CR500
1990 KX500
Happy Birthday Rick General Discussions & Announcements 3 11-12-2011 04:50 PM
I'm so happy! Hawkeye General Discussions & Announcements 2 08-19-2011 10:59 AM
Happy Birthday gasgasman General Discussions & Announcements 17 04-10-2011 08:37 PM
Happy Holidays Berkyboy General Discussions & Announcements 18 12-26-2010 04:22 PM
Happy New Year webmaster General Discussions & Announcements 1 01-01-2007 02:11 PM
