Go Back   Rieju & GasGas Legacy Riders Club Forum > Community Forums > United Kingdom
Old 10-31-2011, 01:46 PM
wasp4banger wasp4banger is offline
didn't need to cut mine at all.
Gas Gas EC 300 '06
BMW F650
Old 10-31-2011, 03:19 PM
rgranger's Avatar
rgranger rgranger is offline
try using dry ice. They use that over here to pop dents out of cars with hale damage. should be rather inexpensive to try anyway...
Rob Granger / Katy, TX EC300
Breaking more things by 8:00AM than most people break all day.
Old 10-31-2011, 05:09 PM
savage sausage's Avatar
savage sausage savage sausage is offline
I dont need to cut mine either, as soon as he started all the waffle I knew that he just wanted to screw me for money.
Old 11-05-2011, 01:32 AM
BigChina BigChina is offline
you wouldn't believe it....but THE simplest way is to freeze it! remove pipe, fill the dented part with water, not full...just enough to cover the actual dent and a bit, position it in your freezer chest so the water sits in the dent. You may have to do this a couple of times. My buddy and I did this for a large dent in his 4 stroke header pipe, took two freezes and the dent was gone. He looked up this trick on the net. We wouldn't have believed it if we didn't do it ourselves. we kicked ourselves for not taking pictures of before and after. its way cheaper and faster than sending it out.
Old 11-05-2011, 10:35 AM
lankydoug lankydoug is offline
That's a great tip and no harm in trying. Heating around the dent and and using ice or dry ice would work on the same principal if you don't have a big enough deep freeze for a pipe to fit in.
Old 11-05-2011, 01:54 PM
HuskyDude's Avatar
HuskyDude HuskyDude is offline
I have heard people using the ice method on 4T pipes. (seamless) But not many success stories on a 2T expansion chambers(much larger volume).
Keep in mind a 4T header pipe has a larger wall thickness and a smaller diameter than a 2T pipe. I think you're looking at two completely different types of dents.
Let us know if you have any luck with the ice method.
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Old 02-12-2012, 08:17 AM
podium werx podium werx is offline
Default exhaust dents
Hi i can blow out dents as long as there not ridged give me a call on 01454 261067 GLOS
Old 02-12-2012, 11:28 AM
GasGas's Avatar
GasGas GasGas is offline
My brother made up some caps for the pipe ends, pressurizes the pipe with nitrogen and heats around the dent. They usually pop out with ease.
2018 EC 300
Old 02-12-2012, 05:36 PM
Default a tad too late
If only you could have seen this post 3 months ago
I've sold it now with dents
Old 02-13-2012, 01:25 PM
hannesd hannesd is offline
what does this dry ice look like, is it a spray can of is it some solid substance?
P3carbon fiber pipe guard Gas Gas stock pipe 08-11 REVERUP Enduro Product Reviews 28 12-30-2013 09:05 PM
Key Removal arminhammer Enduro Electrical & Wiring 11 11-07-2011 07:14 PM
Dent Removal PEB Enduro Engine - 2 stroke 7 12-27-2007 09:23 PM
