#11
OK thanks.
the Cycra CRM also look very good! which cycra model shold i choose for the HEBO? any issue with the instalation? |
#12
Thats the Cycra CRM in eff's photo. I saw them on his bike and they are very nice. Since they do not clamp on the taper of the bar, bar brand/taper does not matter. The point I was making relates to the center clamping width of the bars. Some bars like mini bars (that some tight woods guys like to use for control space) have a more narrow center width, with the upward bend starting closer to center as they are designed for minis with tighter clamp centers. When used on a full size bike, just be sure there is enough straight section outboard of the bar clamps for the CRM clamps to mount to. For you this is easy, just measure this on the bike as it sits now with your bars in the clamps.
#13
Bark busters have a kit that fit the Hebo bars .Google them
#14
Hebo bars used to be tapered like Pro Taper bars, not sure if they still are. I used PT clamps on Hebos in the past, when they were called "Varibars". IMO, tapered clamps are prone to slippage, interfere with hoses, and are a bit old school compared to the other options available.
#15
Use any hanguards and mount with these:
http://bikebonz.com/images/sitebdy/p...hgm/sm_hgm.htm I have Enduro Engineering handguards and tried the EE mounts for the Magura bars but could not get the tapered mounts to hold solidly. Swtiched to the Bonz hand guard mounts and the handguards no longer move. |
hanguards that will actually fit? or change the levers? | dank | Enduro Product Reviews | 12 | 02-24-2010 05:54 PM |
Handlebar Question | grtpumpkin | Enduro Chassis & Body | 10 | 09-24-2008 12:31 AM |
