Old 08-06-2006, 07:59 AM
Eric K Eric K is offline
How much throttle angle rotation is needed for wide open with a G2 400 cam compared to a stock 1/4 turn?
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 08-06-2006, 10:21 AM
iancp5's Avatar
iancp5 iancp5 is offline
I think it's the same or very close - I haven't measured it. I heard somewhere that the G2 cams slow the initial ramp then get quicker. Anyway it feels like you can get WFO with a similar handfull.
Old 08-06-2006, 04:18 PM
gtsnowcrack gtsnowcrack is offline
The throttle cam will allow full throttle but it will take longer.
EDIT:
Example: http://www.g2ergo.com/sitebody/howitworks.shtml
Old 08-07-2006, 06:48 AM
eff's Avatar
eff eff is offline
Originally Posted by jlk_250
I think if you run the 400 in the woods and for MX tracks you switch to the 100 (equivalent to stock) it'll feel like the engine is much more responsive until your body gets used to it again.
Exactly. The 400 cam helps in tight trees, rocky, and hillclimbs.
Old 08-07-2006, 06:50 AM
eff's Avatar
eff eff is offline
I don't notice any real hesitation running the 400 cam. When I hit double track with whoops all I do is hit the throttle and go.
The front end still lofts easily to get over obstacles.
Old 08-07-2006, 11:53 AM
FFRDave FFRDave is offline
I took a good careful look at the G2 websight, and found a .050 cam, but its only for 4 strokes.
I looked for an E-mail adress, so I could try to learn why the .050 can only be used for 4 strokes or if they are developing one for 2 strokes also.
Any ideas ??
Old 08-07-2006, 12:17 PM
jlk_250 jlk_250 is offline
Any ideas ??
Here is the contact info from their web site.
Sam@G2ergo.com - Founder
Info@G2ergo.com - General Questions
Tech@G2ergo.com - Installation & Technical issues
AlphaBITSinc@Gmail.com - Website comments/questions
Old 08-21-2006, 09:59 PM
Treesmacker Treesmacker is offline
I modified the ramp on my son's RM65 throttle tube on a disk sander similar
to the G2. It helps him ride in the tight woods and slows down the hit.
Cost me about 5min. during lunch break!
Good Luck!
Old 08-22-2006, 05:56 AM
GMP's Avatar
GMP GMP is offline
What it does is make the carb slide travel non-linear relative to the throttle rotation angle. The total rotation from closed to WFO is still the same. You have more resolution in control below half throttle with the 200 and 400 cams, but more than that quickly opens the slide to where it would be with the 100 cam (stock).
Old 09-16-2006, 09:13 PM
did anyone else have a bit of a time getting the cable end into 400 cam. I had to unscrerw the top of the carb to get enough cable to pay out and it was still a pain in the arse. Did I miss something along the way?? Swapping out cams isn't something i would want to do a lot of.
Suspension or Mousse tube? wence Enduro Chassis & Body 9 07-28-2010 07:40 AM
GasGas now in you tube Leo Pictures & Videos 3 01-24-2010 04:59 AM
Tube troubles! Need help. svt2224 Enduro Chassis & Body 19 10-12-2008 07:50 PM
FSE400 throttle tube nitroman Enduro Chassis & Body 0 12-22-2007 05:17 AM
fork tube play skid jackson Enduro Suspension 2 09-14-2007 05:47 AM
