Old 07-16-2012, 02:57 PM
troffer88's Avatar
troffer88 troffer88 is offline
I have rode my 2011 a total of three times and the estart is a total piece of sh!t . At first it would not engage all the time now it hangs up after i do get it started and will not disengage unless i blip the throttle. I specifically asked the dealer how they worked before I bought it and he said they were flawless. I would save my money, I am less than impressed.
Old 07-16-2012, 05:03 PM
noobi's Avatar
noobi noobi is offline
Have you asked your dealer if they will help you?
There is a gasket kit you can get that adjusts the spacing of the starter and this seems to fix the starter engaging problem that most people have. It appears to be an alignment issue.
Old 07-16-2012, 05:56 PM
troffer88's Avatar
I have, I have been told that Gofasters shipped the parts last week every week for a month. On a positive note I love the bike , I have owned a ton of bikes and this one is the best bike I have owned period. It is a Ninja, the starter deal is just a piss off because that was my biggest concern.
Old 07-18-2012, 03:46 AM
gasser's Avatar
gasser gasser is offline
Seems like the e-starts work well once the clearance is worked out and a stronger battery is used. I'm just too cheap to spend high dollars for a new battery every other year for a bike that is so easy to start. I've also found that I only start the bike one third as often as I used to before getting an auto clutch.
Old 07-19-2012, 03:47 PM
andykr87 andykr87 is offline
Same deal here dude, my bendix went out after 4 rides and ts 220$. To add to that my kick starter bent the next ride. I wasnt real thrilled. I bought a yz kicker and the estart just adds weight to the bike now. Kinda figured maybe they would warranty the bendix but no luck. Next one wont be a estart for sure! On a positive note the bike is badass other than that. Im looking forward to owning a 12/13 because of the new taller seat height and same 300 motor. Im 6'1 275 so the 11 sits a little too low for me even w a taller seat.
Old 12-10-2012, 08:57 PM
Gasser, did u ever find out if different wiring is needed to swap someone that wants an estart setup. My bikes apart and im looking into canning it for plain ignition case etc.
Old 11-08-2013, 09:17 PM
Bobt250's Avatar
Bobt250 Bobt250 is offline
The starter sucks and I forgot in other rants to say that when my E-start failed my kickstarter broke. I wouldn't waste my money on this E-start. It sucks and is expensive.
2011 EC300
Old 11-09-2013, 07:23 PM
djroggen's Avatar
djroggen djroggen is offline
The wiring is the same. But the connectors are slightly different depending on the application.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
sticking starter Boom Boom Enduro Electrical & Wiring 4 03-21-2011 04:21 PM
starter on 450 ec jenkitchen1006 Enduro Engine 4 stroke (including EFI & Exhaust) 3 05-21-2009 06:38 AM
07 250 Kick Starter prk03 Enduro Engine - 2 stroke 2 03-28-2009 10:59 PM
03 starter clucth gasit16 Enduro Engine 4 stroke (including EFI & Exhaust) 23 12-16-2008 06:42 AM
