Old 04-15-2014, 01:30 PM
Vindicator Vindicator is offline
Very good looking bike ! Congrats ! is the transmission oil level correct ? From the pic seems it has no oil !
Vindicator
'11 EC 300R
Old 04-15-2014, 03:48 PM
Originally Posted by liv2day View Post
No kidding...lol
That's a great looking bike; though I have to admit the taller seat height is a slight bummer for this inseam challenged rider. At least it's not as crazy as my old KTM 300; at 38.8" it was impossible to get a foot down.
I'm curious about the skid plate/pipe guard combo - how easy is it to take off when cleaning the bike? The guard looks like it might catch a whole bunch of muck off the front tire - like a giant mud catcher. I like the concept and it's probably much easier to remove than the 2 pipe clamps typically used on CF guards.
Looking forward to the first ride report
Force guard is a 1 bolt affair! They are heavy though (so someones just given up his weight savings), and as suggested can hold their weight again in mud given the right conditions! Does a top job at keeping the frame rails and pipe in tact though!
Old 04-15-2014, 03:49 PM
Appears to be full to the top.
However, worth confirming as they do ship with no more than a dribble in the tranny!
Old 04-15-2014, 03:56 PM
n_green n_green is offline
Originally Posted by AZRickD View Post
What ?!? You didn't weigh it?
My 12 week old weighs about 5kg. The new bike weighs about the same as me I reckon
It feels a bit lighter then the '11 to push around although isn't as easy to lift at the rear guard, not so much due to weight as the guard on the '14 doesn't provide as good a handle as the '11.
Current:
2014 Gas Gas EC300R
_____________________________________________
Previous:
2011 Gas Gas EC300 ELC
2004 KTM 300 EXC
Old 04-15-2014, 03:59 PM
That's good then, it was put on for me during pre-delivery. I literally haven't done anything other then drool and take photos of it so have no idea how the guard comes off or if there is oil in the tranny. Jake is right though it's full to the top, just brand new oil so still nice and clear.
I don't care about weight, I didn't buy the bike for its lightness, what do I look like a pumpkin eater
Current:
2014 Gas Gas EC300R
Previous:
2004 KTM 300 EXC
Old 04-16-2014, 07:35 PM
Default 2014 Gas Gas EC300R
Woke up early this morning and couldn't sleep so before work I pulled the rear shock out of the new bike. Did some ringing round yesterday and because the reiger is new no tuners have spring listings for it yet.
I really like the '14. I pulled the seat, fuel tank, rad shrouds and silencer off using only an 8mm socket and 4mm Allen key
From there I flipped the subframe up, undone the rear dog bone bolts (still 18mm bolt 19mm nut) and removed the shock (14mm bolt top and bottom).
Current:
2014 Gas Gas EC300R
Previous:
2004 KTM 300 EXC
Old 04-16-2014, 07:37 PM
Took a few measurements of the spring:
Spring length: 267mm
OD: 84.0
Coil OD: 11.65mm
No of active coils: 8
The spring looks to be the same as a KYB spring. This is good because I have a 6.0 spring on the '11. Also the fork springs from the Sachs crossover to the 48mm zokes.
Looks like I'll be putting the stock springs back in the '11 and stealing the heavier springs for the new bike. The 6.0 rear should be on the money, the .50 fork springs were always a bit stiff in the '11 but as they were slightly too long they always had 6-7mm preload on them. Maybe if I have zero preload they'll be ok.
Current:
2014 Gas Gas EC300R
Previous:
2004 KTM 300 EXC
Old 04-17-2014, 08:54 AM
Damn, looks like I may be out of luck with the shock spring. I have an Eibach 5.6 spring here and it is perfect, same dimensions as the OEM spring, but obviously too soft a rate. I pulled the 6.0 spring off the Sachs and while it is the correct ID for the spring seat, it is too large at the top end and can flop around a good 5 to 10mm, unless the spring is perfectly centred on the preload collar it doesnt seem to have enough meat resting on the collar. The OEM and Eibach springs definitely don't have as much play.
Maybe I'm being overly cautious but I'm hesitant to use a spring that can (whilst very unlikely due to always being under tension) move around and place uneven pressure on the preload collar.
Thoughts?
Current:
2014 Gas Gas EC300R
Previous:
2004 KTM 300 EXC
Old 04-17-2014, 11:45 AM
Have someone machine you up a small collar.
Old 04-17-2014, 05:09 PM
That may be what I do. The springs actually come with one that would do the job perfectly. But the ID of that collar is a bees dick to small and won't quite fit over the preload ring. If I can get the ID of that
Enlarged slightly I'll be I'm business. Now which machine shops are open on Easter?
Current:
2014 Gas Gas EC300R
Previous:
2004 KTM 300 EXC
2009 ec300r fork andyec300r Enduro Suspension 8 04-21-2014 06:12 PM
2012 ec300r J. JuJu General Discussions & Announcements 5 08-08-2013 09:05 AM
EC300R '09 Jetting recomendations? stabak Enduro Intake/Carburetion - 2 stroke 12 09-16-2012 06:03 AM
Setting up my EC300R 09 Keg General Discussions & Announcements 4 09-27-2008 07:42 AM
