Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > Parts
Parts New/Used Components and All Bike Part Outs
Old 01-30-2018, 06:19 PM
garacerx's Avatar
garacerx garacerx is offline
TTX inserts would be nice, but they cost 2k
Should I just send my Sachs to LT ?
Old 01-30-2018, 06:21 PM
garacerx's Avatar
Or should I just send my Sachs to LT?
Old 01-31-2018, 03:33 AM
Anders's Avatar
Anders Anders is online now
The Marzocchis are proving to be unreliable; poor wear/failure rates; and hard to source parts for.
I have little experience with the parts situation, but the only time when I needed a Marzocchi part, my Norwegian Gasgas importer got it within a couple of weeks.
Seals and bushings are readily available.
Regarding wear, I have now run the forks (as the rest of the bike) close to 160 hours. I haven't inspected the forks since my last seal / oil service at 120 hours (or thereabouts) but back then there was no wear to speak of. Perhaps the 2015 forks are better than the ones on your (slightly older) bike Jacobi?
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 01-31-2018, 06:22 PM
You should be able to get them a lot cheaper than that. Might be someone with a set of used ones they're willing to sell?
A new set of Marzocchi 48mm PFP forks will run you big dollars too, and I wouldn't buy a set used because.. whoever is selling them will be doing so for a reason...
I found OEM seals and bushings available but priced stupidly high in comparison to other brands. After market options are available though.
I think they have done steady revisions to them with each build, but in my experience the problem is inconsistency of build quality. You get some that are to spec and last a good while, but there have been more than a few reports of them wearing prematurely across multiple brands. It may be a small percentage, but when coupled with the issues with cost and availability when replacing damaged components it becomes a legit concern.
Old 03-30-2018, 08:39 PM
jt633 jt633 is offline
I have a set of gently used 48s off an 09 300, switched to tthe 50mm trick forks have mabye 10 rides great shape if your interested pm me
2004 ec 300
how do i tell what forks are in my gas gas Olliesherman Enduro Suspension 3 06-22-2016 01:46 PM
What forks are these? hadfield4wd Enduro Suspension 15 12-26-2015 11:35 AM
What forks do I have? jprizz Enduro Suspension 7 06-25-2014 03:46 PM
kyb sss forks gassergrant Enduro Suspension 0 06-17-2014 04:28 PM
YZ Forks iamovru Parts 0 03-14-2014 06:48 PM
