#191
Michael |
#192
I converted to a steel ball/spring setup from a WP suspension clicker setup, but that required re-drilling and tapping the hole. Michael |
#193
Thinking about it some more. The spring below the D washer also puts pressure/tension up against the entire assembly from below. I think you could very possibly remove the wave washer completely and it would still work just fine, although he adjuster probably wouldn't turn as easily against the circlip as it does against the washer. Last edited by Jakobi; 07-14-2013 at 04:43 AM. |
#194
Michael |
#195
Michael |
#197
I ended up going leaner as the day progressed, maybe another 5 clicks from where I was, but in hindsight I may go one richer again just to bump the torque back up. Where I am now feels very similar to where I was before on the old needle. I still have a bit of blubber and load up in the single track, but it definitely doesn't bog as badly when cracking the throttle. I managed to make it carry on when I was lugging up a snotty section in second gear low in the revs. Its pretty crisp on the pipe and will loft the front on song in 5th gear. I think its currently a touch lean as it feels punchier a bit richer, but then I get more of the loading up burbling. I may just have to change my riding style to suit. It also seems to run a bit inconsistant, like if I ride it really hard it feels good, but then if I lugg it it loads up and burbles more. The problem is that a typical ride for me consists of a bit of both. Techy 1st and 2nd gear single track through to open 4th and 5th gear windys, as well as everything in between.
Fuel consumption wise I hit reserve at 91kms, from a full tank. |
#198
Seems like where I've been at also. I tried to go lower on the float level and it really pronounced the lean spot after 1/4 throttle. So maybe going a bit higher on the float level, from 20 to 18/19 for example, could take care of the lean spot while still being able to use a lean clicker position for a clean off idle area. I also have a replacement rod coming, but unfortunately I will have a different bike by then so I can't directly compare.
Michael |
#199
How does the SC compare to the 90% Lectron now Jakobi?
'14 Beta 300rr '05 GG DE300 '03 GG EC250 '01 XR440 '09 FZ1 |
#200
I was thinking of going the other way michael and trying a lower float level, and a richer needle position. It may also just be the way the carb is and I'll have to adjust the riding style to suit. Its not horrible or unridable like this.
With the inconsistancies I wonder if its float related. You said you saw improvements with polishing the seat. I may see if Corey will send out one of the other valves to try. Flybars, atm I'd say the SC is about where I had the Lectron when I changed it out. |
APT SmartCarb | gasgasman | Enduro Product Reviews | 1424 | 12-29-2017 05:01 PM |
Lectron Carb | singletracker | Enduro Product Reviews | 145 | 07-27-2013 12:20 AM |
APT SmartCarb | siaknijustin | Enduro Product Announcements | 19 | 10-02-2012 08:12 AM |
brushy ride review, bike review, Add on parts review | Mazikeen | SouthEast United States | 6 | 09-04-2012 05:34 PM |
Lectron | Binni | Enduro Intake/Carburetion - 2 stroke | 16 | 03-29-2011 09:44 PM |
