Old 02-18-2009, 06:13 PM
crem55 crem55 is offline
Smile
Its broken and you dont wont it back. I'll just keep it for you. If you need a bike to ride you can borrow the 02
Old 02-21-2009, 01:20 AM
Pelle Pelle is offline
Originally Posted by ferguscawley View Post
Easiest way to check these is disconnect CDI and use a couple of paperclips to stick down into the CDI connector on the loom (holes in connector are too small for regular multimeter probes)
Be careful doing the paper clip trick, i destroyd my connector... i thought i was so gentle, but hell no!
Old 02-21-2009, 05:12 PM
Alright ,NO more replies, if he knows whats wrong I wont get to keep it.
Old 02-21-2009, 08:18 PM
Brian VT Brian VT is offline
I guess the friggin' thing is broken.
(How cute/hot was Marisa in that flick ? )
Old 02-21-2009, 08:59 PM
fury1's Avatar
fury1 fury1 is offline
crem you know im moving on anyway!
Old 02-21-2009, 10:53 PM
Ok ,The connections on the cdi plug are worn ,whats the easiest fix? Change the connections ,and where can I find the right ones or do we just buy the whole ignition for $378.00? or does someone have a used one?
Old 02-22-2009, 08:07 AM
fury1's Avatar
you sure? we can try the CDI thats on the 200 to be sure its the wiring and not the cdi itself,not sure I see how that can wear out?
Old 02-22-2009, 08:48 AM
GMP's Avatar
GMP GMP is offline
You can use a small pick to slightly collapse the female connector terminal. Clean them up, do this, and use dielectric grease. Tape over connection. If you really need to replace them, you can get waterproof bullet connectors at most autoparts stores.
Old 02-26-2009, 08:06 AM
clerky clerk clerky clerk is offline
Hi, you have probably read some of my threads on hear as i had the same problem and like you I too replaced everything possible including complete rebuild. But nothing worked. Up until approx 3 weeks ago when I lost my temper with the bike and just held the throttle on at its maximum revs and played it there for a couple of minutes, (full revs was just before full throttle, as full throttle seemed to choke out even more) I played the throttle back and fourth a while ensuring it was reving at its max and then suddenly with a little spluttering it cleared and reved the bollocks off its pants. ever since its benn crisp as f@+k.
Old 06-09-2009, 05:40 PM
Someone posted the part number and store to get the cdi connections and I cant remember or find it . If someone could let me know AGAIN. Thanks
2010 Sachs EC300 Fork Problem Bradz Enduro Suspension 4 07-17-2010 03:21 PM
03 EC300 crank bearing problem bwalker98 Enduro Engine - 2 stroke 4 05-04-2010 05:05 PM
ec300 clutch problem dirtjunky_uk Enduro Engine - 2 stroke 13 02-27-2009 08:08 AM
EC300 08 mortal danger construction problem!!! SECRET_AGENT_BOND General Discussions & Announcements 35 06-05-2008 02:39 AM
Gear box problem 07 ec300 peterr Enduro Engine - 2 stroke 5 02-26-2007 01:07 AM
