#21
Take it apart again.
This is what happened to mine. I finally found a scratch on the needle after a few sticks and scares. I replaced it and it happened again. Scary. Needle had same scratch. Something had got into the needle jet and damaged it. I had to replace the carb insert. Ironically my road race bike jammed the throttle a few weeks later resulting in various operations and much non riding time. Throttle assembly damage bits getting stuck.
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) |
#22
Several years ago, I took a GG bike in to work on for a customer. The owner had just bought the bike and the throttle was hanging wide open about half the time after a hard/quick wide open throttle application. I found that the previous owner had installed a "shorter than normal" jet needle. Under smooth WFO application, everything worked fine; but when the throttle was "snapped" wide open, the needle was getting pulled completely out of the needle jet, and didn't always go back into the jet when I backed off the throttle. It made for some interesting times until I found the problem. .
Jim Cook Smackover Racing Team LAGNAF '11 Gas Gas EC250 (primary ride) '06 Gas Gas DE300 2004 Gas Gas TXT300 Pro '94 Husaberg FE350 '86 Yamaha IT200 '86 Honda TRL200 Reflex '04 KTM 525EXC (soon to be dual sported) Several others, including project bikes, Deb's bike, and a fleet of grandkids' bikes Let's go riding! http://www.jebruns.com/Wudi19/wudi19.html http://www.ahrma.org/schedules-results/cross-country/ |
#23
Not reading all replies, but my experience of this happening a few times, was due to my preference of having too much slack in the throttle cable.
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 Last edited by motopsycho87; 09-26-2016 at 03:38 PM. |
#24
Happened again ....
Mixed woods / open fields riding, luckily ? Happened on field section Gonna have another look , Confidence in bike a bit low... Epic otherwise Help! |
#25
Have you taken almost all the slack out and made sure the cable isn't catching anywhere?
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
#26
Stuck throttle
I replace my cables with the 2" longer ktm cable it threads in at both ends can't pull out works great
#27
Check for air leaks
#28
Not touched bike since weekend (apart from quick clean) Gonna get carb out and inspect / clean, also check reeds. Got motion pro cable on order Did Google search and seems to be an orange prob as well. Problem is killing riding confidence at the mo... Biff |
#29
I haven't had it happen to mine since I got out of the habit of enjoying too much slack. Can only be a mechanical niggle, take everything apart, clean and lubricate.
#30
This happened to me on my GG 200 and scared the be-jeebus out of me in a race. What I found was that the cable GG uses is pretty awful. The end of the cable at the perch would pull away from the perch but wouldn't want to come back again. Safety wiring the cable to the perch helped my confidence a tad during the race, but not enough to have a good race. I fixed the problem 100% with the Motion Pro cable. I think that will be the ticket for you. Although I didn't have this problem with my '13 GG 300, I will be immediately replacing this cable on future Gassers just as a precaution if they continue to use that same cable. My husband broke his back due to a stuck throttle, so it's not something I mess around with.
sticking throttle | skid jackson | Enduro Intake/Carburetion - 2 stroke | 8 | 11-15-2010 08:44 PM |
Sticking Throttle | SeanUK | Enduro Chassis & Body | 5 | 12-09-2008 01:27 PM |
Kick starter sticking | jyellard | Enduro Engine - 2 stroke | 5 | 11-19-2008 04:44 PM |
Different Throttle Springs?? | stvbird | Enduro Intake/Carburetion - 2 stroke | 13 | 10-15-2008 08:17 AM |
