Old 10-16-2013, 03:47 PM
Bandit9's Avatar
Bandit9 Bandit9 is offline
On my kicker 300 Race the battery box is that annoying thing you have to remove to get the air filter out. Didn't you remove it and replace with your own brace system?
Blanco
Current ride: 2009 WR450
Previously owned: 12 Gas Gas XC300R, 06 WR450, 06 YZ250, 05 Gas Gas EC250, 05 KTM 450EXC, 02 KX250 w/EG310 kit, 03 YZ250F
Old 10-16-2013, 06:15 PM
modette's Avatar
modette modette is offline
I have an E-Start model that would be silly not to have a battery...LOL And removing the box took all on 1 minute.
Member of AMA, COHVCO, RMAR, Stay the Trail, COTPA
Co-Founder of: TrailTaker
My site: TrailTaker.com
Old 10-16-2013, 06:20 PM
modette's Avatar
Originally Posted by StuJohnson View Post
My 300 is the Racing model and does not have the estart. So I don't know what the battery box looks like.
The reason I installed that bar to the underside of seat is that on the Factory Replica parts diagram it shows this piece goes there. The bad thing is that the holes do now line up but I went ahead and drilled out my own holes and installed.
Why did you have to order a new rear tail light?
Here is a good way to prevent those rubber grommets from falling out.
Drill small holes just big enough for hand grip tie wire to slip through. Then tie the grommets to your radiators or guards (depending on where you have your grommets). - Problem Solved
The tail light broke when I Looped the bike. The cheap poli sport one works but as a tail light it is not that bright so a cop could pull me over. The factory one is pretty dang bright so worth the $90 to me. Could I break it again...sure could.
Good tip, I was going to just use small zip-tie...but yeah maybe I'll do the safety wire method.
Old 10-16-2013, 07:00 PM
Bandit9's Avatar
Sorry, was referring to Stu.
Blanco
Old 10-18-2013, 09:26 AM
StuJohnson's Avatar
StuJohnson StuJohnson is offline
I removed that Battery box immediately.
Prior to installing the new AL subframe I bought the "2TRacing" metal support/hook to keep me seat in place.
Here is what it looked like.
For those who have not upgraded the subframe and don't use the battery box I highly recommend this aftermarket piece.
2012 - XC 300 Racing
Seattle, WA
Old 10-18-2013, 09:58 AM
Bandit9's Avatar
Ahhh....haaaa....
Thanks for that.
Blanco
2012 Poly Subframe twowheels Parts 0 09-12-2013 01:52 AM
2012 snapped subframe Poncho General Discussions & Announcements 21 09-14-2012 12:44 PM
GG Aluminum Frame ruca Pictures & Videos 21 05-03-2011 05:29 PM
