Old 11-23-2011, 06:57 AM
thumperrider1 thumperrider1 is offline
Scrambler, I'm about the same (165lb geared up) and have a 250 coming in Feb. Will let you know what I get for springs. On my 2011 I ended up using 4.0 fronts and 5.0 rear (stock was 4.2 and 5.2). I ride tight east coast single track with lots of trail trash and roots. The stock springs may be fine.
2018 XC300
Old 11-23-2011, 07:46 AM
GMP's Avatar
GMP GMP is offline
This new system will most definately increase the user adjustable tuning scope as far as terrain goes, but a spring is a spring and you will need what you have been running before. I suspect there will be more potential to "dial out" an incorrect spring rate which will no doubt screw up the action of the fork and complicate tuning. This adds another dimmension to tuning from the rider's perspective, but when you think about it it has always been there from the tuner's perspective in a standard CC fork.
I know I'm going to need a rate up on each end, was hoping the Race models would come that way.
Old 11-23-2011, 01:41 PM
FinGas FinGas is offline
I'm about 210 with gear on.. Rear is now 5.4 which is still soft for me. Front is standard 4.2 and it's also too soft for me but i added some oil to outer chamber to stiffen end of the stroke and with pfp i can play the mid stroke pretty well - so i'm in no hurry to get stiffer front springs.
After winter i will change to 5.6 at rear as there i feel the need much more clearly.. Riding in snow: soft suspension is good!
-Mika
Old 11-30-2011, 06:37 PM
SolidPerformance SolidPerformance is offline
Originally Posted by Scrambler View Post
Since I have a 250 coming in the spring of next year,I'm wondering if I will need to have the rear and front resprung for my riding weight of 160lbs?
What type of terrain do you plan on riding the most?
Evan Yarnall
Solid Performance, Inc.
545 Trestle Place
Downingtown, PA 19335
484.593.0095 shop
evan@solid-performance.com
www.solid-performance.com
Old 12-02-2011, 07:49 PM
singletracker singletracker is offline
I'm confused about the 2011 Race xc250. Some people say they come with Marz 45's and others say they come with the Marz 48's. Can someone clarify what actually comes on the 2011 Race xc250, and just how good or bad they are compared to the standard model ec?
Old 12-02-2011, 09:16 PM
GMP's Avatar
GMP GMP is offline
They come with the 48s in the USA. I think some of the confusion about this is there are people here from all over the world discussing bikes in those markets without specifying them.
Old 12-02-2011, 11:26 PM
noobi's Avatar
noobi noobi is offline
I rode a set of stock EC race 48mm CC zokes back to back with my semi revalved 45mm OC zokes. The 48s were much better at dealing with g outs, and higher speed hits, I found them about the same at dealing with trail trash, they didn't blow through the stroke on bigger hits and didn't transfer harshness back to the bars as much as the 45s. They were probably still a bit stiff for my tiny 65kg, but I could have easily raced them with confidence.
Old 12-12-2011, 08:19 PM
rxmx rxmx is offline
Default 48mm Oil Change
I'm planning to dump the oil out of my outer chamber and refill with about 30cc less with 5wt to cheaply soften up my forks a bit. Can anyone confirm I can just loosen the top cap, slide down the outer tube and dump the oil? I'm a suspension novice, and don't want to break anything expensive.
Old 12-14-2011, 12:24 AM
Sure, you can loosen the cap, dump the outer chamber oil and refill to your spec. You will have to let them drain for a bit to get close to a "zero" measurement, but you'll have to assume you will not get the entire amount of oil out of the fork. This will effect your refill measurement. (In this case assume at least 5-10cc will remain in the fork, regardless of how long they drain, unless they are taken apart and cleaned)
Keep in mind, the outer chamber oil is mostly there for seal/bushing lubrication and the progressive spring force at the end of the stroke. So going lighter on the outer chamber oil wont have the "wow" factor of a cartridge valving change, if softening up is what you really want to achieve in the initial stroke. Lower oil height will help with mid stoke harshness in some cases as long as the spring rate is correct.
Evan Yarnall
545 Trestle Place
484.593.0095 shop
Old 12-14-2011, 01:21 AM
Default PFP notes (Updated)
OK, been slammed at the shop with work, but got enough time last week to completely go through the Marzocchi TC (twin chamber) 48's on our '11 250 Race demo bike. As discussed previously, I've been hesitant to change too much before I got a good idea of what I did and didn't like about the fork. Don't get me wrong, not only do I think these forks work great after some minor changes, they have serious potential to get really really good. They just need some TLC (or at least in my case they did) I'll just share some of my experiences, so that others can chime in or see if they too have had the same issues...
Some initial issues I had with the forks:
-Compression clickers have a very faint or non-existent "click" from the adjusters (there should be 6 clicks per turn, 26 total clicks) Mine were barely noticeable on both sides.
-Fork action was harsh on roots, rocks & braking/accel bumps
-Fork action was very quick on rebound, was hard to settle for corners when pushing hard.
-For me the 4.2Nm (.43kg/mm) spring is way to light (I'm 195#) Keep in mind all the new WP forks for the 250/300 Kattoms come with .45 kg/mm springs and 95% never complain.
-Forks had a VERY bad rebound "CLUNK" noise from the front end in hard acceleration chop (ie: sand whoops) Felt like the strg brgs were loose, but weren't (see previous posts)
Initially, over a month ago I simply pulled the cartridge, springs and split the tubs to blueprint the seals, bushings and springs for sizing. My particular forks had different preload btwn left and right legs (5mm difference) It was very evident with the spring seat clip on the cartridge. The seals were also devoid of any seal grease. I greased the seals, reset the spring preload to 5mm (standard) and lowered the oil from 330cc to 310cc. I road this setting for another 300+ hard miles. The fork was maybe 15% better, but still harsh and clunking on hard rebound (Ive been over the some PFP setting issues in previous posts)
Per the issues listed above, here's what was changed/corrected...
-COMP Clickers: disassembled the complete compression assembly, clicker assy and all. Found basically too much grease packed into the ball & spring detent grooves for the "clicks" to be felt. Cleaned out, light grease, compression clickers work great now. Problem solved.
-Checked valving setting with notes from Marzocchi Italy, nothing out of place. There was a large price of rebound piston band jammed into one side rebound valving, which didn't help my rebound issues. Needed a new piston band, so while waiting for my OEM parts shipment I fabbed one from a WP piston band, fit prefect. Problem solved.
-I ditched the stock springs for .45kg/mm set, readjusted the preload with the spring seat clip, ended up with 4mm. The new springs we're stocking for the Marzocchi's fit fit like a glove!
-Surprisingly all four main bushings had a good amount of metal contamination in the teflon already. They were all replaced. A new set of SKF seals were added to match, along with a chrome tube lathe polish.
-Reassembled the forks (STD valving), with OEM spec oil. Took careful notes on the PFP setting relative to cartridge oil fill procedure. Reset oil height back to stock 330cc, clicker base at C20 R15 PFP 2 Trurns. (I know the standard rebound setting is R20, but they are just too fast for my taste)
Went out and pounded some hard NJ sand trails. Damn, forks are like butter on everything. Harshness gone, even better on g-outs, and still turns like a champ. Let a few others ride, they were equally impressed in the improvement. And BEST yet, the F*ING CLUNK is gone! I still think the rebound circuit needs to be slowed down internally, but more on that later.
I'm very pleased with what a simple service and spring change did to the fork performance. I think anyone who's got fork issues just needs to get a proper fork service and spring rate swap for their weight before ANY valving changes are made. These forks have huge potential, don't get frustrated, just get em serviced.
We're stocking complete springs, bushings, seals & oil for the TC fork. If you guys need anything, call the shop I'll be more than happy to help out. Our testing will continue each weekend, I'll post more as it comes...
Note: the cartridge CANNOT be assembled like a normal KYB or Showa fork to set the PFP spring preload correctly, this is critical to eliminating the dreaded "rebound clunk"
Evan Yarnall
545 Trestle Place
484.593.0095 shop
new 48mm Marzocchi forks?? Dave A Enduro Suspension 19 11-04-2011 07:48 PM
2004 ec250 ohlins forks, 46 or 48mm? Mikeythefokker Enduro Suspension 1 04-27-2011 10:39 PM
WP s or marzocchi forks Stoby Enduro Suspension 2 08-19-2010 07:16 PM
