Old 06-28-2012, 07:25 AM
gasgasman's Avatar
Originally Posted by Vindicator View Post
Anyone knows if the stock 08-11 KTM 300/250 is longer than the GG ? Not Motion Pro one but actual one from KTM.
It is shorter, because it routes behind the handle bars.
Old 06-28-2012, 08:22 AM
stainlesscycle's Avatar
does the adjuster nut at the top stay in position? i'm assuming the adjuster cinches against the throttle housing and stays put? and as mentioned before - has no issues with clearing tank (since barrel at carb top on t3 is straight)?
07 ec300
www.stainlesscycle.com
Old 06-28-2012, 09:03 AM
mcnut's Avatar
mcnut mcnut is offline
Yes. the adjuster stays put and is easy to adjust with your bare fingers.
Old 06-28-2012, 04:25 PM
mcnut's Avatar
No issues except for the loose fitting rubber. I lifted the rubber, added a bead of silicone around the metal, and slid the rubber back down. It's sealed now.
Old 07-17-2012, 06:18 PM
rpduc rpduc is offline
I had a not so good experience with this cable. It was about time for a new throttle cable and I happened to see this thread so I went ahead and ordered one.
It does not fit well on my 2005 MC 250. The cable (not the housing) is too long. Even after winding out the adjusters on BOTH ends to what I would consider max safe extension I still had unacceptable freeplay in the throttle. I thought about resoldering the nub on the end but with my luck I woulda made it too short. Plus I'm not exactly sure what that solder is. Silver solder?
I also was not enthralled with the bend that the cable made under the tank as Stainless mentioned. Having to wind the adjuster way out exacerbated this problem. I might have been able to live with that if adjuster was all the way in.
Maybe I got an outlier, but I'll be sticking with the stock set-up from here on out...
Anyone want to buy a brand new T3?
Ross
'05 MC 250
'91 Husky 610wxe
'04 Duc M800 R.I.P
'06 Duc S2r 1000 R.I.P
'07 Duc S2r 1000 still rubber side down...
May be so... May be not so...
My Website
Old 07-17-2012, 06:26 PM
GMP's Avatar
GMP GMP is offline
I've had good luck with the GG specific MP replacement cables, and one of those went on my '12 and fits well with the Flexx Bars.
Old 07-17-2012, 07:09 PM
I had an issue with a normal motionpro cable where the opposite occurred and the outer case was too long meaning I could never effectively get the carb slide to bottom out. I'll have to trim it back a little. I also have a T3 here to try. Hope its a better fit.
Old 07-17-2012, 09:42 PM
erniebearskin erniebearskin is offline
I just fitted the 5.5 longer T3 and its excellent. Thumbs up for cable on 2011 EC300.
Bryan
2013 Husaberg TE250 - Current
2011 GasGas EC300 - OLD STEED
2011 Husaberg FE390 - OLD STEED
2010 Yamaha WR250F - OLD STEED
#53B
I dream of a better tomorrow, where Chickens can cross the road, and not be questioned about their intentions.
Old 08-05-2012, 05:42 PM
Not sure if its been mentioned or not yet, but these T3 cables seem to have one weakness. The rubber cover at the top of the carb doesn't seal well enough to keep water out. After washing my bike, starting it, warming and leaving it for a few days I went to make a jetting change and found the slide all but full of water. Only a little drop in the bowl drain plug. Its either snuck past the seal when crossing a creek, or filled up while washing. I have put a bit of tie wire around it to tighten it up at the top and packed the opening with some water proof grease. Ideally a dab of silicone would be the go but I only had RTV red high temp and would prefer clear for asthetic reasons
Old 09-06-2012, 06:26 AM
n_green n_green is offline
I got a T3 cable and attempted to fit it to my '11 300, however I have a Clarke 12l tank fitted and with the straight connection to the carb instead of the bent connection of the stock cable the tank won't clear it and places a lot of pressure on the cable. I've gone back to the stock tank and haven't tried it again but I'd prefer it if I could just get one of these cables with the bend. Anyone know if I can?
securing throttle cable flybars Enduro Intake/Carburetion - 2 stroke 6 05-09-2010 04:29 PM
Throttle Cable Mishaps carlg Enduro Intake/Carburetion - 2 stroke 11 01-24-2010 09:22 AM
Throttle Cable steve Enduro Intake/Carburetion - 2 stroke 5 02-14-2009 02:39 PM
throttle cable steve Enduro Intake/Carburetion - 2 stroke 5 02-08-2009 06:17 AM
Throttle cable dave948 Enduro Intake/Carburetion - 2 stroke 7 10-10-2008 04:16 PM
