Old 01-05-2013, 06:15 PM
Originally Posted by shark4465 View Post
well still having trouble with yhe pv sticking i have done everything i even cleaned the pv it gets stuck when its fully open have to push it back down
I had this problem at one point. Ended up being a bit of carbon in the cylinder where the pv drum rotates. Take the stop bolts out and disconnect the arm. You should be able to now cycle the actuator plate through a full 360 degrees without binding. I found mine would only snag and bind when trying to turn backwards sometimes. If you haven't done it already pull the whole pv assembly out of the cylinder and make sure you clean everything up really nice. Check for burrs on the cylinder and continue until you are certain it cycles back and forwards. Then reconnect it all and enjoy happy times. I replaced all my bearings for good measure on my second top end. It was cheap enough and I was giving the top end a full overhaul anyway.
Old 01-05-2013, 08:20 PM
shark4465 shark4465 is offline
done it already they are moving perfect it must be the rod or something else ttaking the side cover off again
Rather strange problem on the 11 300 six days bukwheat General Discussions & Announcements 7 04-15-2011 03:08 PM
Strange electrical problem GMP Enduro Electrical & Wiring 14 12-14-2010 08:25 AM
06 EC300 - strange sound when over revved colinmc400 Enduro Intake/Carburetion - 2 stroke 5 05-02-2008 12:10 PM
Strange air leak in ignition cavity d2w Enduro Engine - 2 stroke 4 02-14-2008 01:34 PM
No wonder my forks felt strange JCW Enduro Suspension 2 12-01-2007 04:45 PM
