#31
![]() Quote:
Ended up going to a solid cover again, not sure if it is an older type or a 13 type though. My bet is that it is the older version. Cheers Mark
Xr 250 ( first bike) 98 Rmx 2007 Gas gas 300(swapped for trials bike) 2008 280 Raga replica 2012 Gas gas ec 300 E ![]() |
#32
Check and see if the part number cast on the inside has a 'Mg' preceding it.
#33
That would make it more than 1100 km from my place
![]() Don't think that's gonna happen, but those rocky, muddy singletail's does sound tempting ![]() Where did you buy your cover? Just checked the Spanish and German sites and they are all out of stock on the '12 cover..
Faster, Faster!! Until the Thrill of Speed, Overcomes the Fear of Death.. Team YamaGas Racing. http://bricksite.com/teamyamagasracing |
#34
![]() Quote:
#35
Thanks for the link. But I think I'm gonna try to find it elsewhere..
That guy is making too much money on his spares ![]() The cover is normally prized at around 11Euro, the one on that site it's more than 2x more. ![]()
#36
The '12 cover is fine after being lapped flat on a glass plate, along with the ignition cover. Mine weeped a little stock now no issues. That said, you have to wonder if the oil scavanging vanes on the inside were ever tested since GG was so quick to abandon them. I suspect not and that it was a "shotgun" approach to solving the problem. Honestly they can't hurt, but my older bikes with the alloy covers were just as good. I think its the basket/pressure plate more than anything. Actually they were always good until '11.
#37
![]() Quote:
#38
Flat is flat, so if its done right it should be good I would think. Problem is its tough plastic and a little slow to do. If you don't care about easy R&R of the cover a little Yamabond, Threebond, etc. should work good.
#39
Flat is flat for sure - It took an hour, but I had the entire width of the sealing surface flattened on a granite faceplate with medium and then super fine paper. It still wept between the screws. Had I wanted to put some liquid gasket on it the weaping may have subsided.
#40
I reused the original gasket cleaned with contact cleaner and it was fine.
DIY Clutch Cover Gasket | unclejosh | Enduro Engine - 2 stroke | 8 | 03-22-2012 09:11 AM |
RMW Clutch Cover | Rod Overstreet | Enduro Product Reviews | 2 | 01-24-2011 10:51 AM |
Clutch cover gasket ? | cbutler | Enduro Engine - 2 stroke | 3 | 06-20-2010 11:29 PM |
clutch cover gasket to big? | rupecopp | Enduro Engine - 2 stroke | 2 | 06-10-2008 03:08 AM |
