#31
That is cool!
Looking forward with trepidation to tearing down the 250 completely this fall.
2003 EC250 w/ Ohlins pkg Sometimes you eat the bear, sometimes the bear eats you. |
#32
I got the GG back today with the borrowed head installed. First thing I noticed was the increased resistance in kick-starting it as I performed a few heat cycles. It got up to 103F, so I re-jetted to a fairly rich 175/42. It's tough to discern increased power on the street, but it was ample.
Now I have to wait for RB to get my squish-modded head sent back in Phoenix. What kind of beast am I going to have when that is paired with my new top-end? I may have to go back down to 50T to tame it. Edit: Looks like a one-day turn-around. Just got the shipping notice. Last edited by AZRickD; 06-23-2009 at 05:21 PM. |
#33
Responses from some questions I asked Ron:
.040 is getting low and could need better than pump gas. Closer to .050 would be better. Of course you can make adjustments with base gaskets.
07 EC 300 (under 500 miles, selling soon) 97 KTM 250 EXC (sold) 2016 Trek Remedy 29er |
#35
That's why I live on the edge, SkiDad.
I only got one gasket (.5mm) from the Go-Fasters kit, so if compression is an issue (we'll do a compression test comparison), I'll have to order more. A limiting factor is that "pump gas" "Premium" in Phoenix = 91 octane. On the plus side for me, I ride like a slug and am a short-shifting weenie. I also jet a tad rich and run 40:1 Maxima pre-mix. One last note, my mechanic said my lower bearing was wobble-free. |
#36
yes. but your intercranial bearings have a severe wobble! you done with my head yet? all those insurance papers keep blowing off my desk.
#37
Rick (from a WiFi node at a NW Ohio Captain D's Seafood Restaurant).
I'll be done with my worcation and back in Phoenix and ready to swap heads by Wednesday or so. We'll warm it up, test compression with your head, test compression with my new and improved head. Only then will you see your precious GG head, Mister WhoDat. |
#38
Back from vacation.
I did two measurements using my analog dial calipers not the digital one I used before at the shop. These are the numbers from both sides of the squish (I don't know if they were left or right). .44 / .41 or 1.117mm / 1.041mm .42 / .43 or 1.067mm / 1.092mm I'll button it up eventually (it's freakin' hot in my garage). Rick |
#39
I bolted it all together and had a failure to start -- sticky float and empty float bowl. I did notice a pronounced resistance to my kick.
Once the float was fixed, it fired on the first kick. Something tells me I'll be blowing a few more db at the next race. Acceleration was vigorous in the Phoenix heat. Throttle response was quick. |
#40
Did you ever get results from a compression test?
'05 Gas Gas 300 '97 Aprilia Pegaso 650 '99 KTM 200 '95 ish XR630 (died many times in Oz) |
Fuel lines - Inside or outside of frame? | lukemillar | Enduro Engine 4 stroke (including EFI & Exhaust) | 6 | 09-09-2009 04:57 PM |
Triple Clamps clearance- Does this looks right?! PIX INSIDE | alexpp | General Discussions & Announcements | 8 | 04-15-2009 09:14 PM |
2010 Race model sneak peek | Skidad | General Discussions & Announcements | 6 | 02-28-2009 04:22 AM |
Double pager in Inside Motorcycles | SpeedyManiac | Pictures & Videos | 10 | 12-29-2008 11:17 AM |
