#31
Can anyone tell me if the slide from an AS1 will work in my AS2?
#32
Yes, they are the same slide design.
#33
Jakobi I am about to send off my carb and head for a bit of work, between that and my current schedule I won't be able to ride for the next month or so.
And when I get my carb back it'll be oval bored 36/39mm so I'll have to start from scratch with my jetting before I can run back to back testing with non-notched #7 slide. So, in light of education would you be up for testing my notched #6.5 slide and posting up results. I'm happy to post it up to you and leave it with you for a week or two. If you're keen let me know. |
#34
I just tried the notched #7 again, this time with a richer #48 pilot. Same JD Blue #3 and 180 main. MUCH better! Does not exhibit the lean pilot symptoms and low end is stronger. This is absolutely contradictory to what I have been told about notched slides(that they make the pilot ckt more sensitive and require a LEANER pilot).
#35
Thanks for the offer re the carb. I don't think I'll really have the time other than to drop it in for a quick squirt down the street though. Gimme a few days to recover from the weekends ride and I'll get back to you. I'm all biked out! Should be some good pics and vids coming shortly!
#36
I hope some one can tell me if I may use a jd jett kit for a 36mm.
On my new 12' 250 xc which has a 38mm I believe. A shop has sold me a kit for a 11' gg. I won't name the shop. Thanks Presently I'm running in the bike 170 main 38 pilot Blue needle 4th position #7 slide no notch air screw 2 turns out |
#37
If it is a 38mm your settings willl depend if its an AS1 or AS2. Either way one would generally expect a much larger main to be used. You haven't specified any details re fuels, temps, altitude etc. so hard to provide any more specific info. |
#38
Hmm just pulled the slide out of my mates KTM300 and he has a notched #7 slide so I don't think there will be any point in comparing the two now.
Bugger. |
Jetting: 2011 250 (38mm carb ASII) | Jakobi | Enduro Intake/Carburetion - 2 stroke | 53 | 07-23-2012 06:31 PM |
slide # | jasont1532 | Enduro Intake/Carburetion - 2 stroke | 3 | 04-01-2009 03:13 AM |
In Theory; GG MC125 pipe on a CR125 | Bearman | Enduro Engine - 2 stroke | 0 | 04-10-2008 02:43 AM |
