Old 11-09-2020, 03:23 AM
Louis069 Louis069 is offline
Originally Posted by brads1725 View Post
What are all the details from the carb F5 sent you?
I have a similar thing, when it's hot its fine, free revving all over. But if I do low down work on a tight trail and then hit a fire road it splutters for a gear or 2 then is fine.
175 main 40 pilot and N3EG on clip 2 with a AS1 carb
If your spark plug always looks like my original photo and your jetting isnt too rich then your needle jet may be the issue like mine was. Apparently the jet/metering block seal can cause a similar issue too
2008 GasGas EC300
Old 10-19-2021, 05:20 AM
10411's Avatar
10411 10411 is offline
Hi there,
I?ve been working towards a smoother throttle response on my 2011 ec 300e.
I?m running an air striker 2, 175 main, 40 pilot nedw on 2nd clip from bottom.
I?ve done a lot of reading on jetting basics on the forum.
Bike is good till WOT, then splutters. Any ideas?
Can anyone tell me if there is meant to be an oring sealing the air screw? And point me towards a rebuild kit for the air striker 2.
Thanks in advance.
Old 10-19-2021, 01:26 PM
(F5)'s Avatar
(F5) (F5) is offline
Try a main down and see if its better.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 10-19-2021, 02:55 PM
Originally Posted by 10411 View Post
Hi there,
Thanks in advance.
I was running the nedw on clip 3 so try that and see if you don't lose too much down low. Otherwise I have now moved on to the n3ej which is pretty good but i really need half a clip leaner so n3cj would probably be great but try the 3rd and second clip first on nedw and see how you like it.
2008 GasGas EC300
Old 10-20-2021, 06:35 AM
10411's Avatar
Thanks for the replies.
Appreciate the advice.
Old 10-20-2021, 02:18 PM
both needles work well with the GG, the n3 is more fun though as it has a bit more of a 2-stroke hit, the ne islike a trials bike
2003 txt250 Pro
2013 Ossa 280i
plug fouling problem unsolved fabulous furry Enduro Engine - 2 stroke 29 06-20-2012 10:09 AM
i keep fouling spark plugs??? tom-s Enduro Engine - 2 stroke 7 08-28-2009 01:37 AM
EC 250 Spark plug Grampy Enduro Engine - 2 stroke 11 12-16-2008 12:24 AM
Spark plug gap???? Bandit9 Enduro Engine - 2 stroke 1 08-29-2007 05:26 PM
Plug fouling wheels244 Enduro Engine - 2 stroke 13 05-13-2007 03:48 PM
