#31
2011 Gas Gas EC300 38mm, 2008 Husky TE610, 2003 Beta Rev3 250 |
#32
Anyhoo mine has the 38mm throat so hopefully this will indeed help. One of the things that has me curious about my carb (AS 2) is why it has no low pressure tower above the needle jet. I've seen skoodles of AS pics and they have. Anyone know why it doesn't have one?
#34
somehow I double posted.
#35
The purpose of my testing was to see that things are reasonable. You could test both ways and let us know if you find a difference.
2011 EC250E |
#36
Fred Overstreet 2010 EC250 SixDays 2004 GasGas EC300 -Sold to a good home 2006 GasGas EC250-Sold to a good home 2006 GasGas TXT 280 Pro |
#37
When I installed the JD kit, I found why my bike seemed so grossly rich. The N1EF needle had the clip in the middle groove!
I set it up close to the JD recommendations. 38 pilot, 1.5T, red needle #4, but with a 175 main instead of a 170. The large section of the stock needle measures .1065" diameter. JD's blue is a hair smaller at .1060" diameter. The JD red measures .1075" and provides the leanest idle condition. With the 38 pilot I could get a passable idle at 1T on the air screw. Past 1.25T it was erratic. I changed to the 40 pilot and got an idle at 1.5T out. Past 1.75T it gets erratic. Far better operation than before, but I can only tell so much going up and down the parking lot. The tachometer in the Trailtech Voyager indicates the idle is somewhere in the 2400 to 2500 RPM range. What should a typical idle speed be?
2011 EC250E |
#38
The Voyager default is a traditional 4T ignition cycle (spark every other revolution). I need to change it to the "tach/2" setting (standard 2T or wasted spark 4T).
2011 EC250E |
#39
Diamter of needles. JD Blue ~ E (N1EE, N3EE, NOZE) JD Red ~ W/I (N1EI, NOZI, N3EW) |
#40
The nozzle jet shroud has a fairly large notch in it. There has been some discussion about the value of the notch.
It feels like I am getting some pull-over from the needle since the slide has to be raised to get an idle. Should the air screw be providing all the air needed for idle if the jetting is correct? The higher the slide the poorer the quality of idle. Does a leaner slide pass more air at idle or does it only reduce the "signature" off idle?
2011 EC250E |
Jetting (Another thread) 2011 SD300 | biggstr6 | Enduro Intake/Carburetion - 2 stroke | 0 | 05-23-2011 08:57 AM |
2011 125 6 days jetting | orangezuk | Enduro Intake/Carburetion - 2 stroke | 11 | 04-28-2011 11:09 PM |
2011 SixDays 250 JD jetting (YZ kit) | thumperrider1 | Enduro Intake/Carburetion - 2 stroke | 3 | 04-24-2011 08:04 PM |
Jetting for 2011 xc300 | jeffs2200 | Enduro Intake/Carburetion - 2 stroke | 18 | 04-08-2011 04:09 AM |
2011 jetting | mikemoto | General Discussions & Announcements | 7 | 01-22-2011 03:16 PM |
