Old 06-21-2012, 03:45 AM
theexception_03 theexception_03 is offline
Originally Posted by lonetree View Post
Hi tim,
i would be a little careful about following what others are using in different countrys too, lots of different fuels, this will change jetting alot.
you have plenty of needles to play with to get your bike going well, follow the process as described by jakobi, (thanks for that by the way, cleared a few questions in my head.) and you will work out what is best for your bike...
and if you want, for comparison, as im just over in central victoria, riding similar altitudes, temps and weather, and fuel...
09 250r (with the older scew top carb)
40pj although im going to try a 42 yet.
NEDW 2nd clip
178 main
7 slide.
air screw is at the moment on about 1 turn but i keep playing with it and hence my wish to try a 42pj..
i cant say its perfect, but its bloody close...
dont worry about your cdi or anything yet, try your jetting first...
good luck.
Great to here from someone close to home and with a similar set up, I am getting a bit worried on if I will ever have clean crisp running bike. So many variables, jetting, CDI, Reed valves, spark plug, fuel etc etc.
I will stick to trying different jetting before I move on to anything else.
Just as a matter of interest are you using the BR8EG plug and 50:1 fuel/oil ratio?
Old 06-21-2012, 04:07 AM
Work through the list in a sequential order. No amount of jetting will fix a mechanical issue.
Compression test (may or may not tell you too much, usually better for gauging wear from a reading off a fresh piston).
Pull the carb out - remove all the jets. Soak them in carb cleaner and blow out with compressed air. Clean up the carb in and out and make sure no obstructions. Confirm and set the float height with the carb out of the bike.
While the carb is out - pull the reed block and check the petals for wear. While this is out you can get a visual on the rear of the piston at bdc.
Pull the pipe - Have it cleaned if it looks crusted up. Repack the silencer if it hasn't been done in some time. Visually inspect the front of the piston from the exhaust port. Inspect PV assembly for gumming/carbon deposits while there.
Depending on what you find, take pics, post them, seek opinions, and replace what needs to be replaced. Reassemble, throw a fresh plug in BR8EG/BR8ES, fresh fuel at 50:1 with a quality oil. Amsoil is highly regarded but can be a bit pricey and hard to find in Aus. I was fond of the GRO Synth 7, prior to getting amsoil.
Then, take one of the jetting specs I listed and work with it methodically one circuit at a time. You'll get great results, but you'll never jet out a mechanical issue, and with electrical you can chase your tail replacing parts. If you have a doner bike to swap some parts out with it can help, otherwise reading and multi meter is the go.
Old 06-23-2012, 02:05 AM
Default Got the 250 to idle
Latest results from this setting
DDK #3
45 pj
180 mj
A/S 1.5
Got it to idle really well, no problems
I took it for a 5 min test ride and she pulled really hard from idle to 1/4 throttle
but started to burble or 'miss' once the revs were getting into the high end of the mid range at half throttle
I have attached 2 pics of the plug after this very short test ride, running lean now, so I am wondering... do I change clip positions or go up in the main jet?
Cheers
Tim
Old 06-23-2012, 03:22 AM
Burble/Miss? Different things.. Best way to know the circuit you're working with is to index the throttle. Mark it out at 0, 1/4, 1/2, 3/4 and WOT so you can visually check and be sure what throttle opening its at.
Burble/breaking up is usually a rich condition. Hesitating/missing is generally a lean condition. 1/4 - 1/2 throttle is the needle clip position.
If that was a new plug you're not going to have much luck reading it like that. To read a new plug you need to cut the thread back and read the fuel ring at the base. I use an old coloured plug to test using the upper electrode as if its lean enough it will turn the old colour white/grey.
I'm still going to reiterate what I said before about trying to jet a mechanical issue. You can chase your tail forever otherwise.
Old 06-24-2012, 01:31 AM
Here is my Reed valve, not sure if its in good condition or needs attention.
Old 06-24-2012, 04:05 AM
Hold it up to the light and look through it from the intake side. It should be sealed shut. Hard to tell if there is any fraying on the edges from the photos but in general looking ok. Definately not too bad.
Old 06-24-2012, 06:11 AM
lonetree lonetree is offline
see how its lifting up a bit? the smaller flap....
not supposed to... they should be flush and seal, its a one way valve so to speak....
on my old 04 i just flipped the reeds over so they sealed again, probably not the best, but if there is not chips or anything, as mine were, it seems to work ok.
Old 06-24-2012, 08:58 AM
pscook's Avatar
pscook pscook is offline
Look at it in profile for gaps between the outer and inner reeds. Here's what I did to test my reed's sealing capacity, see if it works for you. It didn't make much difference to me, but there was a host of other potential issues that I wanted to resolve concurrently with the reeds and jetting.
http://www.gasgasrider.org/forum/sho...2&postcount=14
Phil
(New bike pending...)
Old 06-24-2012, 06:17 PM
I'd flip em like Lonetree said. The other post gives a good visual on how they should look and shouldn't. You wouldn't expect that to be enough to cause any major running issues, but as stated, one less variable to work with.
Old 06-25-2012, 07:15 AM
pscook's Avatar
One thing to note when flipping the reeds, there was a step at the base. That made them unidirectional, as in they only fit one way. I tried to flip mine, but the ridge/step at the end made it fit very poorly, hence the rubber band "shim" approach. Just something to watch for.
Phil
Sag setting question Synergy-Seals Enduro Suspension 4 10-25-2011 04:40 AM
Needle advice EC250 darren Enduro Intake/Carburetion - 2 stroke 0 06-19-2009 03:00 PM
Setting up my EC300R 09 Keg General Discussions & Announcements 4 09-27-2008 07:42 AM
Setting up my 05 GasGas EC250 dozerash General Discussions & Announcements 2 09-26-2008 03:01 PM
