#51
I don't see any chest thumping going on here.. just a few different opinions with the general theme being to use what works best for you..
#52
http://www.youtube.com/watch?v=CAb0iRzxSHo |
#53
I spent yesterday on a borrowed 2011 GG 300 with the EXP and LHRB (and a Hyde full coverage skid plate / pipeguard). This combo was nothing short of amazing on the steep rocky sidehill switchback goat trails I rode. The EXP would find traction and climb up anything, the the freedom that the LHRB provided was liberating. I found the faster stuff to be scary and fought the transition from freewheel to engagement and back troubling, but I can adjust to that. This setup made me want to get thumb shifters and get the shift level up out of harms way. This is a very cool setup. BTW, is there a better master cyllinder than using the clutch, I felt too much effort was required to lock the rear wheel and my left hand got tired after a while.
Hbg 496 wec Polaris Dragon 800 163 |
#54
Careful bleeding will help the braking force available. You may try a "grabby" compound for the rear pads. They may be too touchy for the pedal, but may work better for the less force available at the hand lever. I found that I use the pedal for most of my braking. I only use the hand lever when I'm in those tricky, long, gnarly downhill situations.
Newest Spanish Girlfriend: 2011 300 Six Days My Daughter is a U.S. Marine |
#55
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
#56
I just got an 07 EC 300 that has a Rekluse, and want to add a LHRB like I have on both my KTM 300s. Having just obtained this bike the evening before I had to work a 48 hour shift, I haven't had a chance to start dissecting it to find out what I need to do the rear master cylinder to make it happen. I did call Rekluse (as that's the system on my KTMs) and they make no mc insert that accommodates the brake line up to the brake lever, as I would like to keep the foot pedal. I think the rear MC is a Nissin type - Have you guys with LHRBs changed the rear MC to the KTM (Brembo?) type or somehow used the stock MC that came with the GG.....
Thanks
07 EC 300 09 KTM 300 xcw w/Rekluse and LHRB 07 KTM 300 xcw w/Rekluse and LHRB |
#57
It was kit# RMS513 that fit 05-07' GG 4T and 2T.for dual-actuated rear brake. The insert sleave is part# 180-012 that fits a Yamaha MC. The O-ring is Part# 418902 or use a #113 standard O-ring to seal the insert sleave. The brake line is part#419-003A if you are going to use the AJP hand lever MC. Good luck on the conversion.
07 GG EC 300 05 KTM 250 exc 99 KTM 640 enduro |
#58
#59
So, why couldn't you run the LHRB without a auto-clutch?
#60
You certainly can, but you run the risk of stalling the bike unless you are able to simultaneously pull in the clutch lever...But for simply scrubbing off some speed, sure.
Is the flywheel nut a left hand thread on my 300? | bergerhag | Enduro Engine - 2 stroke | 4 | 10-15-2010 11:35 AM |
Experience bleeding left hand rear brake? | roostafish | Enduro Chassis & Body | 17 | 01-06-2010 01:45 PM |
Rear Brake Problem | nsgasser | Enduro Chassis & Body | 0 | 06-03-2008 11:16 AM |
Rear Brake Seizing up | R_I_C_H_A_R_D | Other GasGas Bikes/Quads | 0 | 05-26-2008 05:43 AM |
Sand under left hand PV cover!!! | highspeedsteel | Enduro Engine - 2 stroke | 11 | 08-22-2007 02:36 PM |
